How to remove brakelight cluster, possibly GD?
A query on the Spanish forum is how to remove the brakelight cluster after removing the 2 screws. I suspect it just needs a bit of braver, careful pulling but thought I'd check. Here's the original post:
:link: Cambio luz de freno
Yep, as far as I am aware just a firm pull.  :goodjob:
Offline asathorny
  • Wonky Donkey
  • Curmudgeon
Yep, it clicketh on.  Remove the srews then, as you say, be brave  :goodjob: :goodjob: :goodjob:
Yep, just pull the bugger.
Do it on a dry day and skin friction should be good enough to grip the plastic
