ESP light permanently on
Offline timkeys
Hi
The ESP light is permanently on
That means I can’t use cruise control or switch ESP function on or off
This happened after I flattened the battery and recharged it
I’ve tried turning the wheel full left then full right, as described in the manual
I’ve also tried turning on the ignition with the button held down
All to no avail
I read a couple of posts suggesting it could be tyre pressure, blown stop light or a faulty wheel sensor
Can anyone help please ?
Hi
All to no avail
Have you taken it for a drive, turned it off and restarted? I ripped my steering column out yesterday, had the battery disconnected. had the ESP light on.,  switch made no difference. Took it for a short run, shutdown, restart ESP back to normal.
Also I had intermittent ESP fault and there was a recall for the brake switch and I've had no issues since.
Offline timkeys
Yes I’ve taken it for a drive, it hasn’t made a difference
Sent from my iPhone using Tapatalk
that's me done. Sorry.  Only other thing like I said the brake pedal switch is known to cause issues
Offline timkeys
I’ll ring up a dealer tomorrow
Probably needs a diagnostic machine plugged in to work out the problem
Thanks for the help ?
Offline timkeys
Yes it seems the brake pedal switch is faulty
Break lights don’t come on, ESP light is permanently on and I can’t use the cruise control
Rang dealer, maybe fixed under a recall warranty
https://www.carsguide.com.au/car-news/thousands-of-hyundai-brake-lights-faulty-21245
:link: Thousands of Hyundai brake lights faulty - Car News | CarsGuide
 If it is that which seems likely it will definitely be a free warranty fix. Must have slipped through the net. :goodjob:
Thanks for the update.
Offline John B
  • John B /aka Sloop
      Gold Coast Qld
How good is this forum and these guys that give their time and expertise to help. Very impressed with nz, tw2005, Craig and of course all the members who chip in with advice.  :goodjob2: :goodjob:
  • Toyota Kluger KXR AWD
Loading...
