EPS, ABS and traction control warning sign on dashboard.
Tyb1987 · 11 · 4298
Offline Tyb1987
I have a Australia 2012 hyundai i30 elite CRDI that serve me well for last couple years. I have serviced it at hyundai dealership for every service.
However the dashboard is showing few warning sign (EPS, ABS and traction control warning) recently. I have my last service 1 mo th ago and the 5 years warranty was expiry 2 months ago. I can feel the power steering is stiff than before but other than that the car still driving fine.
What is the root cause for it? I have replace 1 side of my tyre with my spare tyre. Is that going to cause issue to the car?
  • 2012 GD 5 Door, Elite Diesel 1.6lt, Auto & 2017 PD 5 Door, SR Petrol 1.6lt, Auto
Was there a problem before changing the tyre? is the spare the same diameter as the other tyre/wheels?
 :welcome:  :whsaid: Also check all your tyre pressures are the same.
Did this problem start  straight after the service? Check those other things then maybe try disconnecting the negative battery terminal for a minimum of 30 minutes to reset the ECU. That might work. Not sure if you will need a code for your radio afterwards though. Good luck.  :cool:
Offline Tyb1987
Spare tire is same size. Both Tyre are the full size Tyre but the spare Tyre has 6mm thread and old Tyre only have 4mm thread. I have replaced the Tyre 6 months ago and the issue only show up few days ago. This morning the warning signs are disappeared again its drive normally now.
We all prayed for you. Not really, but still a good result after posting on here...  :D
The power of the site !
Scared the problem away  :rofl:  :victory:
Offline Tyb1987
The problem still exist :( :( :(
It's alright in the morning, 3~5 degree in Sydney but the warning signs would still occur when I leave work at 6pm (13~15 degree). I am not too sure how to rectify it.
 :head_knock: :head_knock: :head_knock:
Have you tried all the suggestions in this thread yet?
Offline Tyb1987
All the issues were gone after I swapped the spare tyre with old tyre.  :happydance: :happydance: :happydance:
Excellent! Thanks for the update!  :goodjob2: :goodjob:
Excellent news, we can make any wish come true ...
Unless someone mocks the authority of Khumban-Numena.
