Cartronics TL-01, DM-01, AD-01, FS-02 & GD-03 v2.05.05 Firmware (Aug 28, 2018)
bagerlk · 81 · 28441
Offline bagerlk
      Queensland
Cartronics have just released new firmware for the TL-01, DM-01, AD-01, FS-02 and GD-03 head units dated August 28, 2018 containing Apple CarPlay™, Android Auto™, Bluetooth enhancements and bug fixes. The version numbers of the new firmware are:
SW Ver: 2.05.05
Micom: 3.28.00
Platform: 1.76.00
Please note this firmware file has been removed, it was pulled by Cartronics due to issues, please wait for a later release
« Last Edit: November 25, 2018, 09:56:10 by CraigB »
  • 2016 Hyundai i30
Thanks, you're a champ :goodjob2: downloading it now at 324MB
All installed, works fine :) I've no idea what their bug fixes were as it seems the same, Apple Car Play music is still clicky but that's an Apple problem hopefully fixed in next months update :fingers:
« Last Edit: August 30, 2018, 10:41:52 by CraigB »
Excellent! Thanks @bagerlk
I'll sticky this post.  :goodjob:
Offline dtreble
Thanks!
Installed this in a Santa Fe DM-01M.
It installed fine, but the clock resets after about an hour of not using it. It's driving the missus mad! Any ideas?
I tried resetting the settings and installing it again, no luck so far.
  • Santa Fe
Thanks!
Works fine on the GD unit, did you check to make sure you have the complete version number and firmware? Did you initialise the system after installation?
Offline rakey
      Victor Harbor South Australia
I also installed onto GD-03 unit in my i30. Also having clock and date resetting to 12.00AM and date to 1 July 2015 for no obvious reason, and very randomly.  With reference to the date, was the date on the previous software/firmware version?
  • 2016 i30 ActiveX Auto Petrol with factory sunroof Polar White
Works perfectly fine on my GD-03 unit.
As I previously mentioned...did you check the software version and firmware version were correct? in the instructions it mentions you may need to run the update again if both parts were not upgraded.
Also make sure to initialise the system after the update and not just tap OK or else you have only part run the installation procedure.
Offline IJustKnowStuff
The download link in the RTF document appears broken now. Does anyone have a working link?
EDIT: Literally just bought my car today and thought it had the update already. Don't want to have to go back to the dealer for it to get updated  :wacko:
« Last Edit: September 14, 2018, 12:27:14 by IJustKnowStuff »
  • 2016 i30 Active, 5 Door Hatch, 1.8L Petrol, auto, Polar White
Yep, appears the links were pulled down :(  If my internet were better I'd upload the file for you but it's impossible for me to do so with this ridiculously slow speed :disapp:
Hopefully one of the other members have it :undecided:
Offline rakey
Well, I have re-installed as you suggested, and initialised  as mentioned, so will wait and see what happens. Thanks.
Rakey was able to provide me with a copy of the firmware which I just installed on the GD-03 in my 2016 i30 Active Auto.
Here's a copy of the files I've uploaded to my dropbox: There is hidden content here which only members can see. Please Login or Register.
(EDIT: Mods, or OP, feel free to add this link in the first post of this thread. I won't be taking it down anytime soon by choice)
« Last Edit: September 15, 2018, 05:20:07 by IJustKnowStuff »
Good job, thanks for providing the file to IJustKnowStuff  :goodjob:
Thanks @rakey  & @IJustKnowStuff
I've also secured a copy in my google drive :goodjob: and updated the OP
Offline rakey
Just a FYI regarding the unit resetting to 12AM and 1/7/2015 since the latest software update. I have been able to replicate why this is happening (to my unit anyway).
I hope this makes sense.
When I start my i30 and place it into reverse (auto trans) immediately, without the head unit having time to display the Hyundai logo, it resets to the above time and date.
Strange I don’t see that problem :confused: though my system being an upgrade has the reverse feed wire disconnected, I wonder if this is why the file was taken down :undecided:
Offline singcheng
    • sg Singapore
is the firmware file (in Hyundia_i30_GD-03_Firmware_ver_2.05.05.zip) applicable to Elantra AD-01?
  • Elantra
Offline Simon_Pth
I have the same issue with the click resetting in my Elantra 2017 AD-01.
Definitely went though all the steps and initialised at the end.
Still does it.
  • Elantra Elite 2.0l 2017
Offline anonywhy
      NSW
Damn, wanting to flash this onto my AD unit (Elantra) but am worried about the issues. Is it only the clock issue that you can see?
  • Hyundai Elantra SR Turbo 2017
It’s confusing why I don’t get this clock set issue, mine works a treat.
If your stereo is working fine as it is then there’s not much reason to update it, leave well enough alone if your worried and don’t have the previous file to flash back.
Offline anonywhy
      NSW
I think I'll just flash it, not too fussed about the clock issue. By any chance if anyone could link the older firmware for these units just in case, that would be great :P
My rear camera is quite dim at night, I have a feeling it has something to do with old firmware (as my Wife's i30 got much better after I flashed her firmware earlier on in the year).
Offline the.chad
Hey folks!
Have been digging hard across the internet attempting to find these files for a Hyundai Elantra (2017 model) I just purchased.
Pretty excited to see how Android Auto goes  :D
Hoping to just confirm that this file is ok to install on my Australian model car?
Are the firmware files the same across the different countries?
  • Hyunda Elantra Active 2016 (MY17)
Did you not notice the "au" location in the links to Cartronics Australia :)
You'll have to find out what model stereo you have before attempting the install as you wouldn't want to mess anything up, not suitable for Navigation units either.
Offline the.chad
Obvious point is obvious  :P
Applying to a AD-01 with no navigation, fingers crossed it goes well!!!
Offline aanastasiou4
    • cy Cyprus
I can’t see the link!!
  • Hyundai i30 2012
Still does it.
You mean "clock resetting" try running the update file again as all components might not have been upgraded, system information should list all components in the picture to be fully upgraded.
Offline Simon_Pth
Done the whole process 3 or 4 times.
The FW versions all match up, but the clock still resets.
I can't confirm that it's linked to putting the car into reverse, as a previous poster wrote, but it definitely happens.
Anyway, I'll try load again, but it looks like I'll either have to live with it or flash back to older firmware.
Are there any other AD-01 users that have upgraded and what are your results?
    • cy Cyprus
Is there a way to flash it back? I need to flash back mine!
  • Hyundai i30 2012
