Shiny Red Calipers
Guest · 12 · 5817
Spent the day painting my calipers, it's killed my back but she's come up flash me thinks :cool:
I've still got 3/4 of a tin leftover if anyone in close vicinity to me would like to paint theirs :)
Looks pretty good, , not that I'm into that kind of thing. How about a little write up on how you did them, materials used , prep etc for anyone who'd like to DIY :idea: :goodjob2:
Not hard to do and everything comes in a kit :link: DUPLICOLOR RED BRAKE CALIPER KIT BCP400 HIGH HEAT PAINT RESTORATION DUPLI-COLOR 9782691640000 | eBay
Get the car on stands and remove all wheels - use the supplied spray can of brake cleaner (one can only did two calipers) plus one extra can from SuperCheap for $7.95 and a toothbrush to give the brakes a good clean, let dry for 10 minutes then gave first coat with supplied 10mm paintbrush - have lunch :bbq1: while waiting one hour for second coat then put wheels back on and put her to sleep back in the garage for paint to fully cure over 24 hours :)
Looks good Craig,  now that is a mod I might do at some stage.   :goodjob:
Does it come with the wiite/black paint for the N?
If the calipers had space to write and I had white paint and a stencil I'd put Brembo on it :D
Offline Paolo5
I really like the way that the red of the calipers contrasts with the black of the wheels. Well done! :goodjob:
Thanks, that was my reasoning for going the red option as black wheels make em pop :)
Offline Blazorax
look good dude
Offline ricleo
    • sg Singapore
red and black always pairs well together!
i am just thinking if it's a must to use heat resistant paint, or will regular spray paints work as well? wondering how hot does i30 calipers get to.
i am also thinking of spraying the plastic engine cover with some gloss black and red accents.
I'm not sure how hot they could get though I wouldn't think of using anything but the correct paint, if it fades peels or cracks then it's going to be a bugger to clean off.
The ceramic heat paint I've used is really thick which also helps prevent running into areas that shouldn't be painted, you can also purchase as a spray but it's more work involved having to remove the calipers.
