i30 PD active LED headlights
nogun · 275 · 74424
Offline Purplehazeffc
      Australia, Perth, WA
Yeah Craig. Any of that type of aftermarket dust cover would more than likely work.
But in saying that. That area of the back of the lights is pretty well sealed away.
As most new cars there days, there is not a great deal of room between the back of the light fitting & the car.
I needed to do my wifes 2015 Kia Cerato headlights a cpl of weeks ago. The passenger side I could only just fit my hand in.
Bugger, it's the passenger side for me as well that has limited space with the fuse box in the way :disapp:
guest12451
Stumbled across thispretty interesting auto LED site - it's a bit rough in that the author is clearly non-english speaker but the info is good and cover a few interesting areas e.g Which LEDs work in projector lens headlights
Offline Crustycottage
      Australia, Perth
Just thought i would give a quick update on the cherry tuning LEDS headlights. Not too bad so far, have all bulbs changed over, and whiter light compared to halogen bulbs. Mine are most probably a cheap chinese variant, but they work, covers go on. Longest drive i have done in dark is 1.5 hours with no issues. They are a different fit compared to Purplehazeffc as shown below
Scott, They look like a better adaptor clip than what's available for the GD's.
Any pictures of them fitted :)
      Australia, Perth
I will try to post some pictures tomorrow Craig in daylight, teeny bit scared out in garage with redback spider clan lurking in the dark :Shocked: :crazy2: :scared:
I'm a bit like that with the huntsman and other spiders in my Mower shed..  :rofl:
Now they are different to what I have..    Photo's is possible of whit the rear of the bulb looks like??
Like what type of heatsink design it has.
But once you fit the LED's & the whiter light. It's would be pretty hard to go back to halogens..
I do have these ordered from eBay.   Rather than being 2 sided. They are 4 sided..  :link: H7 CREE LED Car Headlight Hi or Low Beam Conversion Kit Bulbs 6500K 800W 80000LM | eBay
So should in theory give a better & brighter type of light.  I don't use my high beams a great deal.
But will get some LED's for them as well'
800W and 80000Lm :D might want my sunnies on for them :cool: :snigger:
 :Shocked:  yep.. Watch out you'll see me coming up behind miles away  :rofl: :rofl:
Offline galixia
      Queensland
Offline quankino
From what I've been watching thru several Youtube channels, the multiangle or 360* LED bulbs seem to be ineffective because you lose the central point inside the projector housing. Meanwhile with halogen bulbs, you have that and it leads to a better lighting out pattern.
  • 2011 Hyundai i30 FD Trophy Auto
Dantrasy
The JW Speaker Evolution 4000 are two sided at a right angle. Designed especially for protectors their ad says. So I don't know. You Tube wisdom says firing in opposite directions is better.
Regarding my purchase of JW Direct Fit, if the bulb is all one piece I might be able to mod the adapter to slip it round. One cut and twist might do it.
Offline quankino
Have you received it yet? I'm still waiting for your outcome  :mrgreen: :mrgreen:
Aldi has these :
:link: 7" Osram Chip Driving Lights and 22" Osram Chip Bar Light Set - ALDI Australia
would love to see one of these complete kits fitted on the front of a I30 lol
If there's a will,  there's a way  :lol:
      Australia, Perth
In daylight
« Last Edit: August 28, 2019, 04:53:12 by Crustycottage »
Thanks for the photos Scott :)
They’re a neat fit for sure :goodjob:
Curious,  probably mentioned somewhere,
If these beasties have fans on the rear,
how does it circulate fresh/cool air in a sealed unit?  :undecided:
Dantrasy
Not yet. Probably next week.
      Australia, Perth
Good question Mick, of which I cannot answer. Flux capacitor?? Also bear in mind the canbus/ballast resistor inside which warms up nicely too. Seems to work though  :whistler:
Flux capacitor    :rofl: :rofl: :goodjob:
Just thinking that halogen get f-ing hot , have no fan.
Led brighter, same voltage,  less current used so ballast resistor  increases load to trick faulty globe detection,  does heat  then equal or exceed original values?
Given light is a by-product, do led produce more or same heat but draw less current due to its material  composition?
Mick, some info here :link: How hot are LED light bulbs? ? LIFX.com explains some of the differences between halogen vs LED temperatures, not specifically on auto but covers general differences.
Auto differences referred to in this link :link: How hot do LED headlight bulbs get? - Better Automotive Lighting
@CraigB
Thanks mate,
Sometimes my brain is like a dog with a bone,
Other days it's  like ,
Its like the bone after the dog ate it  , CRAP !
Dantrasy
In the event the JW Direct Fit H7 don't work out, I've been trying to research the JW Evolution 4000 H7 for projectors.
:link: LED Headlight Conversion Kit ? Model Evolution 4000 ? Projector Range ? Invision Sales
The spec sheet is useless. No dimensions, no way of knowing if the heat sink screws off.  I'm not sure what the box thing is either. The description suggests it's NOT a canbus module.
Not sure about the V shape. Why is it like that?
I'll send off a few emails. I'll report back here.
« Last Edit: August 31, 2019, 09:54:39 by Dantrasy »
@Dantrasy I believe the locking ring and base are removable on the 4000 series, the box thing is part of the CANbus harness and the V shape is their new design especially for projector lens/beams.
I'm not sure on the sizes either at this stage, still looking.
« Last Edit: August 31, 2019, 07:40:50 by CraigB »
These aren't the projectors but they're still H7 4000 series so sizing would be the same I reckon.
Offline BrendonL
      East Maitland
I got the JW direct fit h7’s on Tuesday and they need an adapter to fit. I have some adapters on the way from stedi. Will update when I get them.
  • 2019 i30 go, manual, white: 2023 kona N premium white.
