2010 crdi engine bay noise.
Misha · 41 · 17440
Offline Misha
  • Sir Newb
      ACT
Hello peeps,
Looking for anyone who would have any ideas on what this :link: Noise from engine bay - YouTube (2 hour cold engine) waffling/wobbling noise from the engine bay would be. Currently at 185k, have had it since at-least 149k(probly a good 10k+ before aswell) when I asked dealer/service to figure and stop the noise, so they replaced the fan belt v-ribbed and called it a day(back at 149k service, didn't take it back in due to money at time). Noise wasn't really there when i drove home, but returned the next morning when cold start.
Note, air con being turned off doesn't change anything
Has increased a little in noise over time since.
Noise is more distinct when engine is dead cold. Then gradually goes away 75% when car has been driving for a few minutes.
Any ideas ? : Alternator, alternator pulley, water pump, timing chain ?
I have next to no experience, so any help or suggestions would be awesome.
  • 2010 DIESEL 1.6lt CRDi (BUILT MAY 10), AUTO SLX FD5DSLX16D31, black
Well, I could guess for you.. got no idea sorry. actually sounds a little bit like the noise I had in one of mine with unknown service history.  Had about 169K, also had a seized alternator clutch pulley  prior to me noticing this rythymic scraping clunk noise. Was making a hell of a racket and belt tensioner was banging away with the seized clutch pulley.
On that one I replaced the clutch pulley , brand new idlers, belt and tensioner which quietened most things down yet still had more oscillation on the tensioner then others I had. None of that may be related but with the tremor I was wondering if the timing chain , guides and tensioners may have been worn.
Anyway, I was going to do the chain but when I saw the cost of the bits and how involved it was I bought a low k wreck and swapped the powertrain. Drastic yes.
Likely  over reaction too.
Now you could remove the belt and briefly run the engine and see if the noise is still there and if it is then it would be inside the engine and I'd think timing chain related.
and that's about all I could say, no idea how serious it may be long term.
keepin mind if you do run with no belt, no alternator running, no water pump either so watch the temp, just do it enough to see if it remains or not.
@nzenigma thoughts?
If you can do another quick Vid with light on the tensioner pulley just to see how steady she is, would be handy , thanks.
I uploaded this but I doubt we'll hear my noise, may show the tensioner vibraion on the belt
:link: Hyundai i30CW D4FB chain noise - YouTube
Offline Misha
  • Sir Newb
      ACT
:link: 11 April 2019 - YouTube
Wasn't 100% sure  which was tensioner pulley :) . Hopefully its there in vid
That's nice and steady. Going to be a process of elimination I'm afraid. Isolate the drive belt, if it goes then you'd spin each pulley for any roughness. I guess you've never taken the belt off yourself before either. Take images of how the belt is routed too before youtake it off if you decide to remove it. Does my head in every time trying to remember.
Motor sounds pretty good otherwise.
if the sound remains, likely internal, does sound very similar to what I heard like something rotating and travelling at the chain end of the motor.
Sorry I can't be more specific or offer any solid advice.
Offline Misha
  • Sir Newb
      ACT
I appreciate it mate, i understand its shooting in the dark trying to diagnose with just a noise, but you've given me somewhere to start ty :) . Havent taken off a belt before, but willing to give it a crack and see how she goes and see if the sound is still there.
On the tensioner pulley, there should be a 14mm hex head as part of the casting, if you have a long breaker bar you should be able to fully rotate it anti clockwiase , at the end of travel 2 holes will line up if you can get a 3mm drill or allenn key in through those holses it wil hold the tensioner arm in place to easily work on the belt, hopefully all this fiddling does not create more dramas for you :mrgreen:
Offline sundiz
      Helsinki
I found that extendable ratchet is superior when taking the belt off. Long enough to get some leverage. Short enough to get under the few cables and hoses. Gap between tensioner and body is small so placing the 3mm bit to the tensioner can be tricky. I never used that. I just let the tensioner open to max after belt is off. Just changed few pulleys today...
  • i30 cw 1.6crdi -08
Just dropped in briefly because  I see all this well intentioned advise being given, based upon an inaccurate  microphone being waved around. Use a stethoscope!!
@Misha  get a short piece of hose, put it to your ear and move it to the place of the noise. Then if necessary remove parts, then do it again.
   :snigger: got it boss, got it   :mrgreen:
well maybe without the funnels :razz:
@nzenigma
 :goodjob2: :rofl:
Making use of that massive trough of public funds?  :wink:
Online The Gonz
:crazy1:
:link: New Single Head Stethoscope Suitable for Medical EMT Nurse Doctor Vet Student | eBay
 :goodjob2:
Thanks Gonz.
I'm getting two.
One for workshop and other for wife who recently found a dead cyclist during her early morning walk.
 :snigger:
Online The Gonz
It won't help the dead cyclist! :head_knock:
P.S. It isn't much use to me in AFG either - I have a tough time working out which bit is any part of a chest. :winker:
:mrgreen:
Nor did half an hour of CPR until the 'first responder' arrived. (6 KM journey) One hour until the ambulance arrived. She never did see the cops.
Now a week later, she did laugh when I offered her the stethoscope.  :cool:
Online The Gonz
Yes, as qualified First Aiders, there's no assuming until the pros arrive. Good on her for doing the hard work. :goodjob:
:mrgreen:
Were they resurrected in time for easter?  :scared:
:mrgreen:
It was only ONE cyclist, same as in the legend.  Dont hold out much hope on either count.  :phone1:
Offline Misha
  • Sir Newb
      ACT
So decided to take a look this arvo. Got a breaker bar from supercheap ( :link: ToolPRO Breaker Bar - 1 / 2 inch Drive, 600mm | Supercheap Auto) only to have it not fit between the gap(head was to long) :disapp: , so had to makeshift a breaker bar with my ratchet and enstion bar which i wasn't happy about, but oh well. Took me a little while to figure out which was tensioner pulley so ive put my crappy drawing for anyone else for future refence :
  ---- I assume its the water pump on the bottom right of pic.... mabye ac , dont know
Belt looked pretty good when i took it off.
Here's a video of me turning the idler pulleys and tensioner pulley : :link: 13 April 2019 - YouTube
Only a little bit rough and only a little bit wobbly from what I could tell.... hard to go off when i don't know what they should feel like in good condition etc.
Started the engine without the belt on. Couldn't really hear much of the previous noise that i could tell. When i put the belt back on tho the noise had defiantly returned.
So im thinking of buying this : :link: Belt & Pulley Kit for Hyundai i30 1.6L 2009-12 4Cyl. 16V DOHC DTFI Turbo Diesel | eBay , figure i might as well replace the belt at the same time with the pulleys. ?Can anyone confirm this is the correct parts for me?
Would anyone be able to tell me which wierd star screw i would use to get off the pulleys ? And if its difficult to do, or its just screw off, screw on etc ?
« Last Edit: April 13, 2019, 08:21:01 by Misha »
$150 is a bit of overkill. I thought you said the belt had just been done?
I'll have a look at that kit to see what it includes. Torx 40 I think, getting in there is awkward, I use a 1/4 drive with 1/4 socket with the bit and just fits. Bit of tape on the 1/4 end of the torx so it don't fall out of socket and drive you nuts fining it in the under tray.
Maybe a torx key but avoid those cheap chromey looking ones at supercheap. One good slip of the torx and the torx slt can round and then it'll be less fun like rounding a philips screw.
Is the plastic idler at top the noiseiest?
Some threads are normal right hand, some are left. , example tensioner pulley, right turn to  loosen,
OEM belt should be 5PK1815, I think you'll see other sizes suggested just because that brand does not do that size
Yeah, That bar is too big, I have that one and the size below which should get in there 450mm I think. The 600mm is real handy if you ever want to get serious and remove driveshaft nuts from hubs and anything serious in the suspension / frame department.
Offline Misha
  • Sir Newb
      ACT
Yes, belt was replaced by dealer 36k ago, and looked in good nick. Was getting ahead of myself i guess :P
From what i could tell (using the diagram from before) the top right IP was the most noisy out of the bunch, followed by the other IP middle top. Tensioner pulley was the best of the 3.
From spinning the other wheels they all seemed good. alternator spun smooth and true IMO
2 x EP230, 1 x EP231 it seems from DAYCO. OEM they just list the idlers, tensioner is complete assembly. Ebay suggests 3 x $37 $111 just for pulleys $46 for a belt, on par. generally they're good for 100000K or 5 years  or so. Could always get it as a spre for next time
One other thing, there was some disagreement on the direction of the bolt in the tensioner, so for the record, both of mine have 14mm std hex head, thread is left hand, clockwise to loosen. I've just checked this on my spare engine.
Some of these have torx heads, they may differ I can not be sure but I'll see if I can find the thread where basically I said left thread, he said right thread. He had the torx headed bolt so be warned.
:link: Drive belt tensioner pulley
Offline Misha
  • Sir Newb
      ACT
All three looked like the same torx screw on mine.
You are the man ! Thankyou for the clockwise to loosen tip ...... could have made my day bad if i went the other way hard :P
Offline Misha
  • Sir Newb
      ACT
Pulleys came in mail today :victory: :victory: :victory:
Was able to replace the 2 idler pulleys easily with a torx 40(only knocked off 1cm chunk of skin...  :whistler:) , they where both anti-clockwise to loosen.
Grooved ilder pulley was only a little noisy. But the flat, top idler pulley was noisy AF, so bearing was definitely shitty.
However I was unable to get the tensioner pulley off, was a torx 30. Its on there well and truly, the cheap torx keys i got ( :link: ToolPRO Long Hex Key Set - Metric / Torx, 18 Pieces | Supercheap Auto) started to bend at the tip, and the bolt maybe threaded like 5% (not much but enough to stop me).
Problem is my torx socket set i have ( :link: Kincrome 11 Piece 1/4, 3/8 And 1/2" Drive Spline Socket Rail) doesn't fit in the gap (unless anyone knows of a 1/4 ratchet thats skinnier than my sideways fingertip :/ )
Started cold engine up, noise is still there, tho definitely less noise, the distinct original wobbling noise is still there, upon further intense continued looking at the tensioner pulley, the noise definitely appears to be in rhythm with the tensioner pulley slightly going back and forth. New short vid : ( :link: Tensioner pulley noise ? - YouTube)
Anyone know of a skinny ratchet and torx socket out there ?
Or if its seized do i have to buy the whole belt tensioner unit to replace it. ( :link: Dayco Automatic Belt Tensioner APV2764 fits Hyundai i30 1.4 (GD) 73kw, 1.6 CD... | eBay)
Offline Misha
  • Sir Newb
      ACT
After looking at this older thread :link: Drive belt tensioner pulley , i'm thinking i should take the drive belt tensioner off completely to work on the pulley freely.
that torx set is the exact one i tried to say not to buy. They are rubbish .
Maybe remove the assembly from the motor. Don't forget someone has suggested the torx on the tensioner is standard thread. I can only confirm the hex heads are reverse thread.
