2012 GD - Window regulator
Offline amit .g
    • il Israel
      Israel
Hey guys,
I have I30 2012 GD made in Czech Republic.
my Vin number is TMAD251CBDJ058980 if it's helps with some thing.
few days ago i turned down the driver side window and after that i wasn't able to turn it up again.
after i had to disassembling the door i noticed that the window regulator plastic is broke  (picture attached).
i was looking on eBay and etc for replacement but all i see is the plastic part only without the iron part that come with it.
i took a look on YouTube videos and i saw that it's different than mine, the plastic and the iron are separate not like mine that are one piece.
someone knows if this part can be disassemble some way?
or where i can find a new one the plastic with the iron part?
right now i will try to paste the part with Epoxy glue and hopes it's will work.
:link: Imgur: The magic of the Internet
  • i30 2012
Welcome,
I can't help with this but I'm sure we have at least one member that can.  :cool:
That looks very similar in design to the FD series which also just snap in time.  Possibility on Ebay there may be some aftermarket ones out there. You won't get that part genuine , I expect it will be the entire inner door panel and regulator in one. Don't loose the metal bit if there is a clip you'll be needing that.
Is the cable in one piece and not all twisted up?
82471-A6000
:link: HYUNDA? ?30 (2013-2017) MK2 CAM KR?KO TAM?R SET? ÖN SOL (OEM CODE: 82471-A6000) - 55.08 TL + KDV
« Last Edit: June 28, 2019, 04:13:59 by tw2005 »
Offline amit .g
    • il Israel
      Israel
thank you for your help.
finally i found full repair kit that fit to my modele.
:link: Buy Hyundai i30 2012-2017 Window Regulator Cable Front Left Repair Kit at TurkishCarParts.Com for only .00 USD
this is the link if someone will need it in the future
« Last Edit: June 29, 2019, 10:37:48 by tw2005 »
  • i30 2012
Nice, funny how my link which was also Turkey / Instanbul has now died.  Had troble remembering where I got my FD bits, also Turkey, now remember. BROSS
Not sure if these suit also, could be slightly different again.
:link: Bross Auto Parts
« Last Edit: June 29, 2019, 11:11:19 by tw2005 »
