Hyundai i30 2008 - I want to upgrade my radio
Offline stevenick100
    • wales Wales
      Cardiff
I want to upgrade my car radio to something modern, my car is 2008.  I'm not sure where to start? Is it easy to DIY or get one shop fitted?  I would appreiate any suggestions or some advice from someone who has upgraded theirs.
Steve
  • 2008 5 Door Hatch, Petrol 1.6, Manual, Blue
:link: HOW TO: FD Body - Remove/Replace/Swap OEM (2DIN) headunit
Looks like a lot of fun. If you are just after bluetooth head unit they are plug and play (if you can find one).
So is this (plug and play):
ns
Offline mc121994
    • ph Philippines
      davao philippines
you can order an android headunit. im also ordering one for mine
  • first gen i30 2009
Offline mrexcitement
I have upgraded my FD wagon with
Sb Acoutsics SB29RDNC-C0004 tweeters x 2
Sb Acoustics SB17MFC35-4 Midwoofers x 2
Alpine UTE-93DAB head unit single din (plays Flac Files)
JL Audio TWK audio processor
Alpine PDX-F6 150w x 4 amp
Alpine PDX-M12 1200w Subwoofer amp
Subwoofer 2 x Dayton audio RSS265HO-4 10" + 2 x Passive Dayton Audio RSS265-PR 10" in 45 litre box.
I have the same bracket as above except it's for a single din unit (didn't want something flashy)
Wasn't very hard to do , if you search on this forum you will find all information needed to remove the factory head unit and wiring.
Best sound system i have listened to in a car.
  • 2021 I30N DCT Hatch
Well done!  I'd love to upgrade the fairly ordinary stereo in my 2019 Camry but suspect I would be too tight to spend the required  $ to get the result I'd want. I just want a bit more clarity, bass  and volume, although my  new hearing aids have helped a bit!
How much did you upgrade cost Mr X ?
About $3000
Although i didn't purchase everything at once , it took a couple of months so wasn't too bad.
I'm bit if an audio nut , so the cost is no problem for me.
Wow! That's probably more than a third of the value of your car. No wonder it sounds good. No criticizing you, it's your money. I'm a tight ass. I wouldn't want to spend more than $1000  to upgrade my Camry Audio and my car is still probably worth $30K.  :-[ so probably wouldn't make enough difference to be worthwhile.
