Parrott install
Offline richard
Hi can any one help. have just installed parrot hands free kit in my i30 when i use it the out side temp gauge goes up has any one else had this  proplem. Cheers richard
Someone did experience this recently, I think it was on our forum. I'll have a search when I get time, unless you want to ?
Right. I knew I'd seen this before, on H-F (I'll provide the link at the end).
Here's the transcript, see if it sounds similar to your problem.
Hyundai People have installed a Parrot CK3100 hands free in my new i30, and while there is a conversation on the mobile outside temperature goes very high like 40-50ÂșC. It goes down at reality some seconds after the conversation is over.
Hello, I too have the same problem, the outside temperature gauge increases when making a phone call. I have a Parrot 3200LS fitted to a 2009 i30 crdi. The installer replaced the whole car kit which made no difference. Did you find out how to fix it?
It appears that the mute cable may be incorrectly connected, as one of the mute connections on my MKi9100 is on the temp  connection, (pin5 on 8 pin brown connector) and this is what they may have used. The correct mute connection on my i30 has no terminals and so I have not connected the mute cable
http://www.hyundai-forums.com/index.php?showtopic=36037&st=0&p=234163&#entry234163
Offline richard
ok thanks for that will try to find and wait for your reply .. Richard
Errr... I posted my reply above :eek:
To close off this issue, Richard has confirmed that removal of the mute cable has cured the problem :)
