GLOVE BOX light not working? FIXED!
Offline mc121994
    • ph Philippines
      davao philippines
I noticed it is a pretty common issue for the glove box light to stop working,
but bulbs are fine and no fuse blown
mine did stop working (or so I thought) until I noticed one night that my glove box lights up when it is closed. ive seen a very dim glow at the edges of the glove box. it made me wonder where it coming from. whenever I open the glove box theres no light.
so I dismantled the glove box and noticed that there is a switch behind it that controls the glove box light. whenever I press that switch it turns on the light and turns off when released. which got me thinking I should just tap it directly to parklight and bypass the  glovebox switch.
and voila that did the trick.. problem solved.
  • first gen i30 2009
Offline mc121994
    • ph Philippines
      davao philippines
forgot to take pics for step by step tutorial. sorry :)
Offline mc121994
    • ph Philippines
      davao philippines
if you have questions, you can message me
<URL snipped>
Administrator Comment Please don't advertise products or services for self-promotion
Let me get this right...
You've arranged for the glovebox light to illuminate whenever you turn on your park lights, whether the compartment is open or not?
Is that not the wrong way round?
I had same issue.
Realised that there was a void causing the switch not to fully depress when the glove box closes.
I put a sticky tab on the box where the switch presses against.
So when box closes the switch presses against the tab and the void no longer exists.
I had same issue.
Hope that doesn't void the warranty..  :snigger:
Offline mc121994
    • ph Philippines
      davao philippines
it is actually the wrong way around and thats why im wondering what caused it... so I bypassed it instead
Offline mc121994
    • ph Philippines
      davao philippines
my unit is 2009 model and theres no more warranty on this thing
Offline mc121994
    • ph Philippines
      davao philippines
yes same with my mitsubishi montero sport, it doesnt have a glove box switch. it turns on whenever you turn on the parklights
