From new my car has had some contamination on the windows - especially the windscreen. It is invisible on a dull day but in sunlight shows up like a crocodile skin pattern resembling a not-quite transparent film on the glass. On a cool morning when moisture has misted the glass, even with the wipers running, the contamination is uncomfortably visible bordering on dangerous when driving into the sun.I have tried several so-called glass cleaners with limited success. What do you guys suggest.
Could it be the shatterproof lamination showing through, and not actually any removable debris?
I was convinced it would the internal lamination layer as suggested by a forum bureaucrat somewhere up the thread, until you mentioned your success. What does a razor blade do for you? Please refrain from replying with descriptions of your morning shaving habits.
Thanks for the comprehensive reply, Adam.
I'd recommend 99.9% Isopropyl alcohol for that particular issue - presumanly your rubbing alochol was less concentrated?something like this, its all a bit price gouged at the moment as it kills c-19 500ml (0.5L) ISOPROPYL ALCOHOL 99.9% PURE IPA ISOPROPANOL LIQUID: Amazon.co.uk: BeautyBest thing for cleaning wiper blades tooand many other thingsbut its HIGHLY flammable.and wear gloves is strips all the oil out of your hands otherwise.A rub with clean dry newspaper can help shift it too!
If you have never tried, screwing up a page of a newspaper, & using it to wipe over the car windows after cleaning them with fav cleaner. You should try it!!Give that a go Alan.
