Hi all,
Looking for a bit of advice. I got the car serviced recently and the technician advised me that the oil had risen above the F marker by a few mm. Now I added oil awhile before this just a top up but don’t believe I overfilled. He mentioned to keep an eye after this service as it could indicate injector problems.
Now the query I have is - after the service, cold - oil sat at F. In the manual it states to drive the car to operating temperature and sit for 5-10 mins and check. When I do this, the oil is about 2-3mm above the F ‘dot marker’. However, if I check when cold on a flat surface first thing, it’s about 2-3mm below the F marker, which indicates some oil has been used. Before I got the i30 I never heard of a car having oil checked at operating temp, only ever when cold.
What do you guys think? Do you check when cold or hot? Thanks in advance.
