Throttle body air intake clamp can't be removed
Offline b2goodbath
      Geelong
Hi Legends,
I'm trying to remove this clamp and appears the head of the screw circle shape and I don't know how to remove it.  Any recommendations?
Hyundai i30 85KW CDRI 2009
Cheers,
Moises
  • 2009 FD 5 Door wagon, Diesel 1.6lt, Auto, blue
Online The Gonz
Is that a metal or plastic cap? Can it be removed to reveal normal grooving for a screwdriver? I'd be surprised if it didn't come off. Worst case, clamp and turn with pliers.
That looks like the rear of the jubilee clip. Is it loose enough to swivel round...?
Online The Gonz
I'm not sure it is, Steve. The free end of a hose clamp tends to be on the same side as the screw head, for a normal clockwise thread.
You could be right Gonz - I was just looking at the shape of what's visible
Pliers it is then.
Offline b2goodbath
      Geelong
It's a methalic cap. I tried with a flat scripdriver to remove it but its impossible. Also I tried with pliers and a locking pliers but cap can't be removed and I can't unscrew neither turning... That's why I wrote I thought is weird...
Stick a medium flat screwdriver down between the thread and clamp then belt it with a hammer :)
Not sure about your weather at the moment, but with rubber and with some plastics little bit of heat makes them more easily removable without damages. No flame, but hot water or wifes hair dryer.
Looks also that little bit of WD-40 might do the trick.
Online The Gonz
