Hyundai i30 1.6 CRDI D4FB diesel engine problem ????
kriskot · 3 · 10493
Offline kriskot
    • bg Bulgaria
      Bulgaria
Hello all and sorry for my english at start
I have a problem i own a nice combi i30 1.6crdi 2009
Last night it worked fine no strange noises or anything
This morning i try to start it and just a click the engine won't turn on
So i tought well battery/starter/etc starter fuse/relay
I've checked the starter and the bendix will drop down but doesn't turn so i replaced the starter the same thing just 1 click and nothing more
The strange thing is when i try to turn the key on all power in the car it dies and when i stop trying to start the car everything works
I tought the engine siezed so i turned the crankshaft by hand clock wise and no problem it turns
So starter is good ,battery is good,fuses or relays good BUT doesn't even try to turn the engine
I love that little pur pur diesel engine i just hitted 362,500km oil change every 10k km 5w30
Other things oil level is good there isn't any oil in the anti-freeze
Once again sorry for my poor grammar and i hope i get some help in monday i'll get a tow truck to a shop but till then i hope i can fix it with some lill help
I
  • i30 1,6CRDI 66kw 2009
It still sounds life a bad battery to me. Did you check voltage under load?
How old is the battery?
How did you test the battery?
If tested what volts readings?
Are the leads on the battery fully home a tight?
Have you tried jump starting to see if it starts?
If it does then battery is my main suspect.
