2016 I30 CRDI Loosing Coolant
Rattly1 · 4 · 10590
Offline Rattly1
      Qld
Morning All,
I have the above hyundai and it has been going well
Last November, it threw a check engine light, Hyundai dealership tracked it to a plug had come unclipped(?????) from the EGR harness
Ok no worries
Anyways drove it out of the workshop and the check engine light came on again  :'( :'( :'(
This time they changed out the EGR on warranty
My son drove the car from then till May/June when my daughter got her licence ( My son has no interest under the bonnet!!!!! )
We then lifted the bonnet (as I was showing my daughter what to check) to find the coolant not in the header/expansion tank and also it took coolant in the radiator
Took it to the dealer ship as there is no coolant making it too the ground
They say they found a loose hose clamp and tightened it
After this it continued to loose coolant still not to the ground
Took it back to dealership
This time they pressure tested it
 No loss of pressure or leaks
  They also did a CO2 check apparently clear
They then found that the radiator cap was failed (?????)
After another week of driving it is still loosing coolant
So back to the Hyundai repair shop!!!!
Just wondering if anyone else has had the issue of lost coolant but no sign where it is going???
The oil is not milky
There is no condensation under the oil filler cap
Can coolant go out through the EGR
As I work with heavy earth moving machines, I have seen EGR's fail and leak coolant as they are cooled via the coolant system
Im unsure about these Hyundias
Cheers for any help
Rattly
Just an update to this
I have had a ph call this morning from the workshop over the weekend the I30's coolant system was pressure tested all weekend pressure dropped Saturday morning the pressure was pumped up again and was gone again this morning
The workshop then took it for a good drive down a range and back up Combustion gas tested and sure enough it has got combustion gas in the coolant
So needless to say the head is coming off
Still in warranty till November I hope they honour it  :head_butt: :head_butt: :head_butt:
heres hoping :confused: :confused:
« Last Edit: August 16, 2021, 03:14:59 by Rattly1 »
  • 2016 I30 CRDI Manual Marine Blue
Offline sundiz
      Helsinki
I dont't know about the newer engine, but in the older ones there is egr cooler. Hot egr gases go through it and if it leaks coolant it can be tricky to find. Pressurising coolant might show if therr is small leak somewhere.
  • i30 cw 1.6crdi -08
Paul_king
If the cooling system is not bled properly then this can happen.  As your driving the coolant will be pushed out through the over flow on the header tank. I have been fighting this problem over the last few months. I thought I had solved it. I was wrong.
I bought my car 8 months ago and it had no coolant in it. It took 2 litres to top it up.
Paul_king
Spent all day yesterday bleeding the system took it for a 50 mile drive parked up left it over night checked it this morning and it was perfect.
I did start her up left it too idle and it took an hour to get up to 70c  using the thermometer in the expansion tank.
I then took the revs to 1500 rpm for 15 mins and the temp reached 88c left the heaters on for 15 mins and switched it off.
Let the coolant cool down and after an hour or so the coolant had dropped from max to min so I topped it up. I will use the car as normal this week and check it on a daily basis. Hopefully  it’s sorted now.
