Help should pipes be connected to these
bowyer · 6 · 1870
Offline bowyer
      cornwall
 Was wondering if this is correct? And if the pipes should be connected to the two inlets and what do these pipes do?
  • i30 2009
Looks like someone has disconnected the heater core hoses.
PGN I30
As above, looks like the heater matrix has been bypassed, is probably blocked or leaking.
Offline bowyer
      cornwall
Thanks had some work done on it a few weeks ago and they had forgot to reconnect it up. Does it matter which pipe goes to which connection if so does anybody know which one goes where thank you. As do not want to use that garage agian long story
  • i30 2009
Doesn't look like they forgot to reconnect the hoses - that blue connector looks quite deliberate. As above, probably bypassed due to an issue with the heater core.
As for reconnecting, you may find the hoses refit in the order you see in your photo - they're probably not long enough to be misfitted.
Offline bowyer
      cornwall
May be worth flushing out the heat core that try and find the fault out. If it’s the heat core I bet it may be expensive to replace! More that the car is worth!!
Thanks for all your help
  • i30 2009
