Another cold start issue thread [i30 GD 2014]
Marioux · 18 · 5941
Offline Marioux
Hello everyone,
I've having trouble starting the car on cold temperatures. On some pretty cold days it was almost impossible (-17). Mechanic had checked glow plugs, battery, fuel filter, air filter. All good. Seems like a fueling problem ? I don't know. I don't get smoke or anything like that. I've put a tester on it and the guy said the tester detects a very high temperature in the exhaust system. I don't know if this would have any connection with the start issue. What do you guys think ? I made a video. Once turned, the car works fine with absolutely no issues. But once it stays a couple of hours in cold weather the issue comes back.
:link: Cold start issues - YouTube
Lower you volume when the outside temperature sensor comes up. That ding noise is pretty nasty for the ears. You might blow your speakers out  :)
Thank you. Have a good one.
PGN I30
Have the glow plugs been removed and checked the ohms reading, has the glow plug fuse been checked?
Any fault codes from the reader?
Offline Marioux
Thanks for your response. No. He just verified using a small 12 V lightbulb. All 4 lighted up the bulb...I know..he should have removed them but he didn't took the risk to remove them cause he was afraid they might crack when trying to remove because the car stayed outside for a longer period in cold temp ... That's why he only checked them with this "method". He didn't and neither did I cross my mind to check the fuse box. Will check this out this evening. No fault codes on reader.
PGN I30
Have you also tried priming the fuel filter before starting just in case it's a fuel starvation issue?
Offline Marioux
Hello. You referring priming it manually ? If that is what your are asking than no. Because the car runs once it starts, I presume there can be no issues with the fuel filter. I had it replaced 6 months ago. It's a quality fuel filter.
I always let the fuel filter light go off before turning the ignition . Also the glow plugs indicator. In fact, 2 times I've turned the ignition and let it crank some many times, I ran out of battery voltage at some point lol. Had to "borrow" some power from a friend's battery using cables. Made sure he'd stick around :)
I also tested the injectors. 2 of them had to be reconditioned cause they failed the fuel return test. They were returning fuel 2 times faster than the other 2. I've got the control valves changed thinkin' this might resolve my issue but it didn't. After the change, I got worried cause right after I left the service shop, I had some unusual vibrations on idle (I felt it on the driver seat). Also, the vibrations were slightly perceivable when I was accelerating the car between 1000 and 1500 rpm. Drove it like that like 5 km the and both vibrations disappeared. I guess it was an ECU adjustment to the 2 injector valved changes ? I don't know.
Have you checked fuel pump flow is ok.
When left fuel may be flowing back and therefore not at point of use at initial start up.
Or pump not working correctly.
Offline Marioux
Yeah, it's in service right now. They said they will check the pump and also do a compression test. Waiting for feedback.
Offline Marioux
Just got back from the mechanic. The issue seemed to be this cable. Car starts fine now. For anyone who may have the kind of issue I had.
Offline kamxsd
      United Kingdom, Europe
Is this all part of one big wiring loom or does it split into several separate wires.
In my photo below, I am guessing it is one with the blue tape and yellow plug at the end?
  • 2013 Hyundai i30 1.6 CRDI
Offline Marioux
I'm not 100 % sure but I think you are right. That seems to be the same cable. I don't have the one from the left.
But the issue came back ! :( Car worked fine for a month (weather was warmer). These last days since the issue came back, were pretty cold.  I'm pretty sure it's a starvation fuel type issue like @567 I30 and @eye30 assumed. Waste of money :( I have another appointment on Tuesday. Will post here some feedback.
Offline kamxsd
I have the same consistent eight second long crank starting problem with my 2013 crdi since I bought it three years ago at 120k. Hyundai main dealer change the fuel filter. I changed the glow plugs and high cca battery. No improvement. 3 years and 55k miles later. Car remains reliable but the 8 second crank is still nagging me and I want to figure out what's causing it is it any chance that as a starter motor or the solenoid starter motor to could cause the problem?
Once it started in the morning there is no problem I could do 50-80 stop start deliveries and every time engine restarts in less than 2 seconds without fail.
Friend of mine has the exact same make model and year. His car start within 2 seconds even if it's been sitting for a month. The other thing I noticed is that the cranking speed on his is noticeably faster.
PGN I30
Have you checked the glow plugs are working? Is the glow plug fuse OK?
Offline kamxsd
1st car is mine, 2nd is my friend. same make, both high mileage 165k+ 2013 and 2014
Is it me or is there a difference in the cranking speed ?
2013v2014
Offline TerryT
      Sydney, NSW
2013v2014
I listened to the video yesterday, twice.   First time, I thought both cars sounded pretty much the same, didn't detect any noticeable difference.  Second time, I thought I heard a slight, subtle difference before I had to log off.
But today when I went back for a second listen to the video, it is unavailable.  And now I cannot remember what car I suspected.  D'oh!
Full disclosure, I have tinnitus and one bad ear, but my hearing would have been degraded the same for both cars so... :)
Offline kamxsd
PGN I30
First one I wouldn't necessarily say is slower but it does sound a bit more noisy/rough like bad bearings maybe.
Offline TerryT
      Sydney, NSW
I listened three times.  Could not pick any real difference with cranking speed, just a slight difference in the 'tone' or noise.
Offline Marioux
This might be an earlier conclusion but I might have resolved the long cracking issue that I've had! I changed this piece and the long crank dissapeared ! But to be absolutly sure I will have to wait the winter for colder temperatures to hit lol. The issue didn't manifest itself on a 10 degrees outside temp. Before I definitly had a long crank unde same temperature.
36720-2A800 -> glow plug bus
