Genuine N parts on the N Line, yes/no?
Ensō · 3 · 2363
Offline Ensō
I've had a bit of a search around and can't really find much on the matter. But does anyone know if it would be possible to swap parts off my N Line to genuine N performance parts? I think in theory it should be mostly fine but I'm just too unsure to start. (Exhaust, brakes, suspension, etc.) Has anyone done this themselves? I'd like to give it a try but I'm not sure if it would be a waste of time. Oh and I've got a 2022 i30 N Line btw 😁
  • 2022 I30 N Line
The N has far superior brakes and suspension, whether they would fit the N Line I have no idea, I'd also expect the N to have a much stiffer subframe to make use of the better suspension.
The N doesn't use the same engine as the N Line so I wouldn't expect exhaust compatibility.
« Last Edit: February 28, 2023, 15:20:49 by CraigB »
I had to check through Hyundai Australia, the N has electronically controlled suspension so it's not compatible with an N Line.
