Here's an update on replacing the lower engine mount, the one at the front that controls rocking backwards and forwards. First step is to lift the front of the car on ramps or similar so you get underneath far enough to remove the plastic tray. Then, drain a couple of litres of coolant from the radiator, catching it in a bowl so it can be put back when finished.
Remove the air intake ducting by undoing the two bolts holding it one and pull the hose away from the air filter box. Remove the radiator fan by first undoing the bolts that hold it in each top corner, and the bolt in the middle that attaches the hose clip. Disconnect the electrical plug, and pull the top-up hose off from where it attaches to the expansion tank and the radiator. Pull the radiator fan upwards whilst holding back the clips in each bottom corner. The radiator fan can then be lifted out, holding the top-up hose and big water hose out of the way as you pull it up..
With the radiator fan out if the way, it's much easier to get to the engine mount. remove the long bolt that goes through the middle of the mount, then the two bolts which can be seen from above. There's another bolt which has to be done from below. All bolts are 14mm AF
Fitting the new mount is just following these steps in reverse. Don't forget to refill the coolant tank.
I didn't buy an OEM part, and had to file out the holes for the upper bolts in order to get the bolts back in. Seriously guys, it's 2023, is it too much to ask to have holes in the right place?
