0 Members and 14 Guests are viewing this topic.
Just had a chat to the "Techy" at Nulon and compared the B4 and B5 ratings, discussed what was most suitable for the i30 etc.They recommend the Full Synthetic 5W-30 Diesel Formula Long Life Engine Oil.European : ACEA C3-08, A5/B5-04 or the B4 version.
Quote from the website:Nulon Full Synthetic 5W-30 Diesel Formula Long Life Engine Oil is designed to provide the ultimate protection for all technically advanced passenger cars and light commercial turbo charged and non-turbo charged diesel engines that require a fuel conserving 5W-30 low viscosity engine oil. It is specifically formulated to provide protection during long oil drain intervals and is safe to use in modern diesel engines fitted with catalysts and particulate filters.
They said to check what the dealers are using as the "service oil" and see if we can go better than that by using a premium oil of OUR choice. I told him that is exactly the feeling in the owners group and the reason for the research and ongoing discussion. They are so similar that we would not notice the difference, so I asked "why make them" and they said that some manufactures call for B5 specs.Things like shear values, wear factor, and a heap of others are all equal. There is a slight fuel economy advantage in the B5....but that is under testing conditions and would not necessarily show under road conditions, where there are so many other variables. They said to check what the Hyundai dealers are using as the "service oil", check that oils specs and see if we can go better than that by using a premium oil of OUR choice. The implication being that they might use a "bulk" synthetic oil that does the job!!
I told him that is exactly the feeling in the owners group and the reason for the research and ongoing discussion. I also mentioned that the more detail they make available to enthusiasts, the better for the company and acceptance of their lubricants by those enthusiasts.
So, the plot "thickens"..
Historically, when the i30 was released we were up to '04, so B4-04 should be the minimum to adhere to. B5 wasn't invented so it's hard to say exactly where we stand with this, however I maintain that B5 is not by definition a B4 spec oil and therefore unless Hyundai change their requirements, B4 must be used. So the above recommendation of a B5 oil is not going to satisfy the warranty - nor me . I say again: do not use B5 oil.
So what do you do in 10 years when B4-04 oil is unavailable? Oil like all technology moves on, you can use oil which exceeds the original specs, as long as you don't fall bellow those specs.
For the Oil Industry Specifications Is says :ACEA C2004, C3-04, A3/B4-04, A5/B5-04
Quote from: Pip on January 06, 2011, 04:14:58Historically, when the i30 was released we were up to '04, so B4-04 should be the minimum to adhere to. B5 wasn't invented so it's hard to say exactly where we stand with this, however I maintain that B5 is not by definition a B4 spec oil and therefore unless Hyundai change their requirements, B4 must be used. So the above recommendation of a B5 oil is not going to satisfy the warranty - nor me . I say again: do not use B5 oil.So what do you do in 10 years when B4-04 oil is unavliable? Oil like all technology moves on, you can use oil which exceeds the original specs, as long as you don't fall bellow those specs.
We seem to be forgetting that Tony posted the info that was on the back of the 5W30 Diesel Formula Long Life bottle...QuoteFor the Oil Industry Specifications Is says :ACEA C2004, C3-04, A3/B4-04, A5/B5-04So, unless Nulon is telling "porkies", this oil does in fact meet the Hyundai requirement of a B4 oil...Yes? :-\
QuoteSo what do you do in 10 years when B4-04 oil is unavailable? Oil like all technology moves on, you can use oil which exceeds the original specs, as long as you don't fall bellow those specs.In 10 years time IF oil is still available, the way oil prices are rising you wont be able to afford to buy it anyway Why buy a 1.6 litre engine, chip it, tune it,port polish it etc, just to squeeze another 20 bhp ?buy a bigger engine its easier, and doesn't run the risk of invalidating your insurance
Quote from: rustynutz on January 06, 2011, 11:46:30We seem to be forgetting that Tony posted the info that was on the back of the 5W30 Diesel Formula Long Life bottle...QuoteFor the Oil Industry Specifications Is says :ACEA C2004, C3-04, A3/B4-04, A5/B5-04So, unless Nulon is telling "porkies", this oil does in fact meet the Hyundai requirement of a B4 oil...Yes? :-\I don't know how to explain this apparent anomoly. It's quite possible that I'm wrong but I can't work out how one can claim meeting both B4 and B5 tests for the same oil.Anyway, if it meets B4 then who am I to say it's no good if it meets Hy requirements?
Dear Mr xxxxx, Hyundai Australia appreciates the time and effort taken in notifying us of your concerns.You can use this specific oil as long it meets the “ACEA B4” specifications. You should be able to find out it meets the requirements, by reading the information that’s on the bottle.Thank you for your enquiry and the opportunity to respond. Regards, Colin Kim Customer Relations Officer Hyundai Motor Company Australia
What an interesting chart , Good work All we need now is some explanation of how it is best interpreted, like is more shaded area better or less for instance? For any 1 oil spec, is it better to have a finger in each part of the "pie"? Is a dominance in just a few "Pie" areas a good thing? It seems that as the oils move from -04 to -08, then the size of the shaded areas increase...so is that a good thing?
So, is it a good thing to use an oil that exceeds the manufacturers requirements,or is it detrimental ??/ :-\
.. Re the inference that a B4-08 spec will be better that a B4-04 spec, makes one wonder if and when Hy will change their recommendations.
