I agree with Terry that most tyre shops know how to inflate tyres correctly.Not sure about his claim that car manufacturers set the pressures higher for longer tyre life.
Seriously though. In all my years in the tyre industry I never heard that said.
... what is important in a tyre ...
Quote from: Surferdude... what is important in a tyre ...Air
I'll take another note tonight when I leave work, when they are cold and when I get home (an hour drive).
LR barely changed after two hours diving today. That’s two minutes was just in the work car park.
Last time I had 4 tyres fitted at a well known chain in UK, the tyre pressures were all high because the manager had told the fitter to keep putting air in until the TPMS light went out. Clearly, he was oblivious to the need to drive the car for a while at the correct pressure for the TPMS sensors to 'learn' what the correct pressure should be. The other thing to watch out for if you have a slow leak is whether it's leaking around the bead. This would show up using soapy water but to do it properly the wheel should be taken off and laid flat so the water settles around the rim. A friend had this problem and it turned out the tyre fitters had applied too much pressure on the machine that grips the rims when putting the tyre on. The rims were no longer perfectly circular, but slightly flattened where the rim was clamped, so the tyre bead didn't sit in it properly allowing air to slowly fizzle out.
Quote from: BrendanP on April 08, 2023, 19:56:19Last time I had 4 tyres fitted at a well known chain in UK, the tyre pressures were all high because the manager had told the fitter to keep putting air in until the TPMS light went out. Clearly, he was oblivious to the need to drive the car for a while at the correct pressure for the TPMS sensors to 'learn' what the correct pressure should be. The other thing to watch out for if you have a slow leak is whether it's leaking around the bead. This would show up using soapy water but to do it properly the wheel should be taken off and laid flat so the water settles around the rim. A friend had this problem and it turned out the tyre fitters had applied too much pressure on the machine that grips the rims when putting the tyre on. The rims were no longer perfectly circular, but slightly flattened where the rim was clamped, so the tyre bead didn't sit in it properly allowing air to slowly fizzle out.As the air pressure which drives a tyre fitting machine is fixed, this wouldn't be a tyre fitters problem. More related to the machinery.Whilst I've seen an alloy wheel scratched or gouged by the lever used to guide the bead over the rim, I've never seen a rim actually distorted.The clamps used are on the back (inside) of the rim and hold it against a flat surface.
