Cold start hyundai i30 1.6 crdi 2009.
Sax · 1 · 2072
Offline Sax
    • cs Serbia
I have a Hyundai i30 cw, 1.6 crdi, 90 hp, 2009. It burned a little harder, the battery was under warranty, the starter was made because it was slower (it changed brushes and bushings, rotor bearing), it worked better but still fired from the 2nd time. Checked fuel pressure and pump on diagnostics, everything is ok, there are no errors and parameters are ok, heaters removed and checked, everything works. As the weather is colder now, it starts from the 3rd time and it always happens when the engine cools down, when engine is hot, all is normal and started normally. Is there anyone who drives the same model with that engine and had such a problem ?
Poslato sa JNY-LX1 pomoću Tapatoka
  • Hyundai i30 cw
