Are D4BF motors interchangeable between year.
Offline fristhyundai01
      Brisbane Australia
I have a 2009 model and want to replace the motor with a 2016 model. the 2016 model comes with it's own wire harness. is it as simple as plug and play or will I need to plug a code reader into it.
  • 2009 i30 diesel hyundai
I hope you're experienced with diagnostics and wiring as the ECU is different and likely all plug connections will be different :crazy1:
Also are the engine mounts in same location?
