Clutch wont disengage after new parts
Offline krisaron
    • ee Estonia
      Estonia
Clutch failed dramatically, throwout bearing copletely destroyed and clutch disc was very thin. After replacing the clutch disc and pressureplate, throwout bearing, clutch fork and both the master and slave cylinder the clutch pedal only goes about 3/4 of the way down and it won't disengage so I can't put the car in gear. There's nothing under the pedal, when the bleeder valve on the slave cylinder is opened, the pedal does go all the way down. I can push the clutch fork towards the slave cylinder by hand and there is a little free play up and down in the clutch fork.
I don't know what to do and I have tried everything I could think of.
  • 2011 Hyundai i30 1.4i manual
