problem with ABS pump
Offline ester90
    • pl Poland
      Katowice
Hello, the ABS pump in my fiancée's car was damaged - there was constant air in the braking system. We bought a used one and took it to a workshop for assembly. After collecting the car, the brakes worked perfectly, but errors began to appear on the dashboard - all safety systems did not work.
We sent the old pump (the one that was originally installed) for regeneration - they replaced all the valves.
As you can guess, after installing the regenerated pump, there is still air in the system.
We are not giving up, we are looking for another one, but at the moment it is impossible to find one with the identical symbol.
Ours has the symbol G440.
Here's a question for the forum members, do you know whether it must be a pump with the same symbol?
P.S. I will only add that I also own an i30pd from the same year and with almost the same version of equipment and my pump has the symbol G421.
best greetings from Poland :)
  • 2019 / PD /5 Door / Hatch / Pb / 1.4 MPI /Manual /Polar White
Offline Greyhound
Try entering your car VIN number into partsouq website https://partsouq.com and see which part number you find there for your specific vehicle.
  • i30 PD 2020 1.0 T-GDi
Offline ester90
    • pl Poland
      Katowice
Thanks for answer!
the numbers are correct, but I don't see any information whether any other pump will also fit. because it's hard to find pumps with the same numbers at the moment.
I noticed that the numbers are two-part 58920-G****.
The first number is always repeated, which means the second part?
Or maybe someone knows whether a pump marked, for example, G421 / G445 / G471 / G488 will work?
  • Midlands, UK N-Line T-GDi
I think you may need the right computer system to operate all the valves to bleed the block.
Offline ester90
    • pl Poland
      Katowice
the car was twice in a workshop specializing in Hyundai and, of course, it was bled using a computer
