Login
Register
Menu
Home
Forum
Search
Gallery
Help
Contact Us
August 12, 2026, 04:59:24
THE GARAGE (SERVICE, MAINTENANCE & REPAIR)
DIESEL
Timing chain
Timing chain
T19ger
5 ·
1143
« previous
next »
Print
Pages:
1
Go Down
T19ger
1st Gear
2
United Kingdom
Timing chain
March 07, 2025, 07:37:29
Hi guys newbi here... I've got a 2015 1.6 crdi and was wondering if anyone has a rough idea on replacement also if anyone knows what chain kit I'd need as I can find a couple of different chain kits
2015 gd 5dr hatch 1.6 auto dark night
liability
2nd Gear
51
Australia
ACT
Re: Timing chain
Reply #1: March 08, 2025, 02:13:56
How many kms have you done? I have a 2015 CRDi DCT auto with nearly 400,000kms with no issues.
Unless the chain is making noise, why do you want to replace it?
Active X CRDi DCT
BrendanP
Technical Advisor
585
United Kingdom
East Midlands
Re: Timing chain
Reply #2: March 11, 2025, 13:30:47
As long as you perform regular oil and filter changes (every 10,000 miles or 12 months) the chain should last, and last, and last. Obviously, only use a top-brand synthetic oil. I never replaced the chain on my 2011 FD diesel after almost 300,000 miles. My 2015 diesel has done 119,000 miles and it's not crossed my mind to change it. Unless you can hear the chain rattling or slapping, I wouldn't worry about it.
i30 CRD
Greyhound
3rd Gear
272
United Kingdom
Re: Timing chain
Reply #3: March 11, 2025, 16:13:46
I wonder if
@T19ger
is confusing timing chain with timing belt. The latter (i.e. timing belt) require preventative replacement at a certain mileage/km to avoid driver and wallet disappointment.
I have seen article about recent adoption by some manufacturers of wet timing belts instead of dry belts. Seems some wet ones may be failing prematurely, due to mechanical wear and being subjected to chemical effects of oil.
A timing chain, not a timing belt, is something I look for in an engine spec, for more peace of mind.
i30 PD 2020 1.0 T-GDi
T19ger
1st Gear
2
United Kingdom
Re: Timing chain
Reply #4: March 11, 2025, 17:09:40
Its on 71k miles and making a horrible rattle. I'm going to get someone to have a look thanks guys
Print
Pages:
1
Go Up
DIESEL
Timing chain
Search
Username
Password
Always stay logged in
Forgot your password?
