scraping noise when turning, steering wheel lock to lock.
0 Members and 50 Guests are viewing this topic.
Offline Rob ATM
hi has anyone experienced, a scrapping noise when turning the steering wheel from lock to lock, the flexible coupling/ spider gear was replaced 16/11/22
now this noise has developed, the dealer is telling me they have traced the fault too worn steering column bearings, needs replacing customer to rebook
(meaning find a s/hand column for them to fit) as new is obsolete, I cannot find an exploded view of the column to see what parts might be worn?
I'm having a local mechanic, remove it to investigate
THE Hyundai ACTIVE is a 2013 1.8lt, DOHC GD, ATM ENGINE G4NB, VIN KMHD251
  • 2013gd1.8auto
Hi Rob ATM
Enter your VIN at http://partsouq.com and you'll be able to find & drill into the steering section to see an exploded view. I believe.
Offline I30 GD
I had a scraping noise on a Ford many years ago, it was the steering clock spring.
  • I30 gd
Offline thommo101
      Perth WA
  • 2012 GD i30 Active Diesel Manual
Interesting. In 2022 I had my steering bush (the little star shaped plastic thing that disintegrates) and clock spring replaced in the steering wheel on my 2012 GD. About 3-6 months later I started noticing a bit of a light scraping noise when turning my steering wheel fast, less noticeable when slow.
On my next service I had the mechanic have a look. He used a stethoscope to isolate the source of the noise, and claimed it was coming from the electric motor assembly that sits on the side of the steering column. This could possibly be the same thing that your dealer is mentioning?
I'd be very surprised that a particular part would be obsolete. Perhaps the dealer just doesn't want to replace only a single component?
Anyway, the mechanic said he could replace, or we could just monitor it. I said I will keep an eye on it. That was 2.5 years ago and I don't notice the noise anymore (it might still be there and I'm just used to it?). Car still drives fine!
  • 2012 i30 GD CRDi Active manual
Offline Rob ATM
thank you, for your help, I will let you know the outcome
  • 2013gd1.8auto
Pretty sure I had that on my FD.
I felt it was something touching the plastic shrouds around the column. It never got any worse and like the poster above, eventually I didn’t notice it anymore.
Certainly had no effect on the steering at all and never got any worse.
Just as an aside, If you’re near Fulcrum suspension they know what they’re doing.
Offline Rob ATM
update on 2013 hyundai  gd, I had a Steering mechanic check it and he confirmed I need another steering column pretty sad really!
 we have ended up with an unserviceable, unavalable obsolete column on a 2013 vechicle  well off to the wreckers we had already replaced the spider gear, checked the clock spring on the original column  blah blah. will keep you posted thank you .
  • 2013gd1.8auto
