I30N not starting after crash
Offline Sandeep55
Hi guys, I’m trying to get my i30N back on the road. It was crashed 4 years ago. It cut off when the crash happened. And not been started since. Unfortunately water did get in while it was sat as the windscreen was taken off, the modules behind the dash were not communicating with each other. I have bought a donor i30N to fix it. I swapped out all the modules but the car is still not starting and shows an immobiliser logo. The only thing I haven’t swapped yet is the rear proximity sensor for the keyless entry. The fuel pump won’t engage and the starter doesn’t turn on when I try to start it. Airbag module has been changed. And I even swapped the ecu and the steering lock as they might be coded to the other car. If you guys have any advice, I would appreciate it.
  • I30N fastback
