Bass-y music and resonance
dino · 5 · 2025
Offline dino
Hi guys,
have had my i30 for a week now and am noticing when I am putting my music up to 15-20 the back left door is resonating. I noticed this in the loaned i30 I had before I got this one, so I am curious to know if this is a documented or common problem.
Any suggestions on how I might be able to fix it? It gets super annoying. If I push the door from the inside, it stops completely.
Thanks in advance.
Have you balanced all the speakers to get an even sound?
If you do this it may sort itself out.
Offline dino
As in, Settings>Audio>Balance? These are set at defaults if that's what you are talking about.
Hi Dino not a common complaint.. I would try adjusting the tone (bass and treble in case the particular frequency is causing the vibration)
If that doesn't help try taking the trim off that door and checking the rivets that hold the speaker are snug.. If not you may have to drill them out and replace with screws..
If not loose could try packing the panel with a thin foam draft excluder strip when you push it back on.. :idea:
Or complain to the dealer and get them to fix it..
I'm sure others will have different ideas.. :razz:
Yes.
But you can alter each side, as Daz says, and by doing so remove the offending issue.
