1.6 diesel - Idle speed, how noisey at idle and air con whine :)
BarryD · 3 · 2688
Offline BarryD
      Milton Keynes
Having owned my i30 now for almost am month, I am very happy with her - DPO (dumb previous owner) seemed to tail gate a lot as I've had to tidy up quite a few stone chips, but maybe they were just unlucky.
3 Questions / requests for information:
1. She's got 24k miles on the clock, and was serviced just before I bought her around £22k miles.  Now the oil is pretty black and she's a lot noisier than my old diesel Santa Fe was at idle,  I am thinking an oil change would not hurt and may make her quieter.  Thoughts?
2. She seems to idle around 1100 rpm, settling down to 800 after about 30 seconds whenever I pull up - is this normal?  If this is indicative of slight over fuelling then I can see another improvement in MPG possible.
3.  Air-Con I'm guessing the pump is electric rather than engine driven.  When I turn it on there is a definite increase in noise, again is this normal?  Should I not be able to hear it?  Maybe if I leave it on for a week or so it will quieted down.
Overall I'm really pleased with the car, and the above niggles are so minor I would normally not mention them, but it's Friday lunchtime and I'm bored at work LOL
Hi "bored at work" :D
1. Mine's 3 years old (61,500 miles) and is quiet at idle, though I guess you could say the noise level is pretty much subjective.
2. Mine is the same, settling down to around 850rpm after a few seconds (less than 30 seconds, that's for sure)
3. My AC is engine-driven; its pulley is always spinning with the engine but pressing the AC button causes an electromagnetic clutch to connect the compressor to that pulley. In my case that's accompanied by a slight judder of the engine as the load is taken up, followed immediately by an increase in fuel delivery to compensate for that.
4?
1. She's got 24k miles on the clock, and was serviced just before I bought her around £22k miles.  Now the oil is pretty black ........... I am thinking an oil change would not hurt and may make her quieter.  Thoughts?
I wonder whether they used the correct specification/grade of oil.
Just checked mine and although it is dark it is not black
1. She's got 24k miles on the clock, and was serviced just before I bought her around £22k miles.   ...............she's a lot noisier than my old diesel Santa Fe was at idle,  I am thinking an oil change would not hurt and may make her quieter.  Thoughts?
Mine is noisy at start up from cold but quite after about 5 minutes.
Mine idles around 850/900 rpm
Mine is noisy on settings 3 and 4.
