Removing rear door (boot) cover on a CW
Offline Ugly Mongrel
  • H.O.S. inmate
Does anyone know how to remove the inside cover of the rear door cover on a CW?
 I'll have a look tomorrow um and let you know,its a bit dark at the moment.  ;)
  • H.O.S. inmate
Thanks 2eyes.
Offline jabber
      Blacktown, NSW
hi UM
i recently undid the boot cover of my CW to install a rear view camera.  see if these photos would help ...
the main boot door liner has screws which you should undo first with a Philips head screwdriver
then i started off by prising off the center panel which is on the upper or top of the glass
be very careful not to break any of the studs (or holders like i did  :disapp:).
once off, work your way down to the side panels. i found these ones easy to come off ...
after these, i simply lifted up the main liner of the boot door just to grab the camera wire i fed thru.  i didn't take the rear door cover fully off as i found no need to (and was also  :scared: of breaking more studs)
hope this helps ...
Thanks for that Jabber .. Nice clear photos  :goodjob:
  • H.O.S. inmate
Thanks jabber. Great shots.
that was easy,the hath cover looks like it would come off the same way.  :idea:  great job jabber.  :goodjob:
  • H.O.S. inmate
Hi jabber. It was as easy as it looked in the pics. Thanks so much. :D :D :D
Offline jabber
      Blacktown, NSW
