Personally, I don't think it is possible to over-inflate the (front) tyres in any sensible way.
Quote from: Pip on June 08, 2009, 14:31:21Personally, I don't think it is possible to over-inflate the (front) tyres in any sensible way. Then perhaps you are living in cloud cuckoo land? Over inflation can lead to loss of grip earlier than a correctly inflated tyre.Car and tyre manufacturers spend millions on research. Do you really think they do not know what they are doing?In the event of a serious accident it may well be that an under or over inflated tyre may be considered a contributory factor.
New here but been reading a bit here and there.Picked up my new car just under a week ago and decided to check the tyre pressure today.Tyres were filled to 36psi by the dealer.
I think Baradeur is right. I have an i30 Diesel 1.6, and it came with 42psi in the Hancook tyres when supplied new, and I'm convinced this is way too much pressure.After quite a bit of driving It seemed really noisy and bumpy especially on motorway trips, I'd heard this was mainly due to the Hancook tyres and assumed they were just rubbish. I had to do an emergency stop and the ABS kicked in really early and I travelled way further than I thought I should have and nearly collided with the other vehicle.After this I did some more testing (emergency stops) at those pressures after checking on line and with my hand book and I wasn't happy with the grip or noise so I lowered to 34psi front 32 psi rear (I only drive myself in the car and don't carry any weight) I must say the noise has lowered to a more comfortable level and the grip is way better than before on stopping, cornering is also fine. The wet grip is excellent with the esp "on" as well, so maybe those Hancook tyres are not so bad after-all, Anyway I have settled on the above psi as a good compromise on those tyres on the i30 diesel.
Just home from doing a defensive driving course with my wife, through Driver Dynamics http://www.driverdynamics.com/Great day and we both had a great refresher on the joys of ABS and ESP.They were adamant that cars should be running at least 40psi for maximum grip, and also for best firewall heat dispersion in the tyre.BTW I wish this forum used Australian and not US spelling in it's spell checker.
Just home from doing a defensive driving course with my wife, through Driver Dynamics http://www.driverdynamics.com/Great day and we both had a great refresher on the joys of ABS and ESP.They were adamant that cars should be running at least 40psi for maximum grip, and also for best sidewall heat dispersion in the tyre.BTW I wish this forum used Australian and not US spelling in it's spell checker.
Quote from: druggist on May 24, 2012, 08:32:22BTW I wish this forum used Australian and not US spelling in it's spell checker.I'll look into it, cobba
I checked my tyres today to see what pressure was in them.I was surprised to see they were at 37psi. The sticker in thedoor trim says 32 for 17" wheels. I know some people on hereare using 34 - 36psi. What pressures are people using and what psi would be the maximum you would put in safely.
