Hi again Ivarella...Overall the i30 has terrific Owner satifaction results and a relatively low failure rate .. but I know that doesn't help you..
everyday when I open the Brazil i30 Forum, someone has a problem and today another got the same problem I have after his first service.
Quote from: lvarella on July 06, 2010, 14:39:46everyday when I open the Brazil i30 Forum, someone has a problem and today another got the same problem I have after his first service. Can you give a brief list of what the problems are just to see whether anyone on here is experiencing them.
Sorry Ivarella but can you remind me where yours is Manufactured (It has to be a manufacturing issue because the i30 uses good components like Bosch etc...)
You described the noise as "tec-tec-tec" but the video sounded more like a dry bearing noise to me. Tappets sounded like a good bet as they make a ticking noise like a sewing machine. Perhaps it is something like a bearing in the alternator or timing belt tensioner. Either of these may have been loaded by a belt retension during the service. It will be very interesting to get the final diagnosis but I can't link a spark plug to the noise at all.
Well if they say they've "solved" the problem, you'll soon find out (click to show/hide)
Hi Ivarella .. that is Crazy (especially if your car comes from Korea like the Aussie ones do ) Failure/problem rate over here very low compared to other brands...
Have they tried changing the oil to a different one at all?
Quote from: Mutley on July 09, 2010, 00:50:14Have they tried changing the oil to a different one at all? im thinking that also.
