Can I program them myself or ??Sent from my SM-G900F using Tapatalk
Maybe I will use only one key then 😁😀Sent from my SM-G900F using Tapatalk
I've already disconected the battery many times when the car was at my mechanic for other issues.Do I need to do it again?Sent from my SM-G900F using Tapatalk
Quote from: Kliment on December 14, 2016, 08:31:38I've already disconected the battery many times when the car was at my mechanic for other issues.Do I need to do it again?Sent from my SM-G900F using TapatalkYour car exists because there is an inert chip in your key fob. The ECU/transponder are programmed to accept only IT.I think you probably have a key from a different car.
Leon posted a good clip, covering removal of the transponder.I know you've probably seen it but I'll relink it anyway HOW TO: Dismantle the remote keyfob
As said, the open close function is separate from the chip and it's start function.Take both keys and the car to a locksmith who does vehicles. They will analyse the functions immediately. In Australia, no need to go to Hyundai to get the (expensive) work done.
Quote from: nzenigma on December 14, 2016, 08:46:23Quote from: Kliment on December 14, 2016, 08:31:38I've already disconected the battery many times when the car was at my mechanic for other issues.Do I need to do it again?Sent from my SM-G900F using TapatalkYour car exists because there is an inert chip in your key fob. The ECU/transponder are programmed to accept only IT.I think you probably have a key from a different car.But if its from another car how can I open and close my car with that one ??Sent from my SM-G900F using Tapatalk
