Car won't start this morning
z24o · 48 · 31981
 :whsaid: Same plug, tricked me too. Well done, Asterix  :goodjob2:
Offline z24o
      Tasmania
....so what is the plug that the rat chewed for?
And is it ok to drive the car with the engine check light on,I believe it is to do with emissions?
Provided the wiring has been repaired, insulated and secured properly, what does it matter. The engine check light is probably the result of a stored fault code, which will need to be cleared by software. Remember, there really was a fault when the wires were chewed.
A detailed inspection need to be performed to ensure the rats haven't done damage that's unseen.
Quote from: z24o
As Phil says, if you could get your hands on an OBDII dongle (I have one - it costs peanuts) and some software (I use a package on my smartphone) you could clear the trouble code yourself. If the code returned, you'd have to investigate further but I think it'd stay off if you cleared it.
Offline z24o
      Tasmania
Final chapter
Drove the car to the dealer,they patched in and soldered an extra length of wire into the plug and cleared the fault codes
Hey presto,good as new
Thanks for all your help
^-- did they charge you much?
Offline constipated
Any official comment on what the exact wire that was chewed was connected to?
Offline z24o
      Tasmania
Offline z24o
      Tasmania
Cam sensor
$115
couldn’t you say it was a feature of the car - like the nodding dog you put on the rear parcel shelf.
Is that an insurance situation at all. $115 for a rat.  :argh:
Not unless z240 had an excess free policy (unlikely)  :disapp:
Offline z24o
      Tasmania
Correct....went down that path ....and I'm $400 better off,not to mention being back on the road a week sooner
I've just dug out my old thread on this (here) and I offer my apologies - you are quite right Asterix.
This was the pic I took of my tuningbox connector - it's where you said.
I just looove when I'm right...  :happydance: :snigger: :snigger:
...and hard to convince when I'm not.. :mrgreen:
Offline eugene188
    • ca Canada
      Ottawa, Canada
  • MY2011 Elantra Touring, Automatic. Ottawa, Ont. CA
We had a similar problem with squirrels at our place. My friend even had them build a nest in his VW, which resulted in all the grass and wood chips catching fire when the engine got hot!!
The simple fix for it, is to get some dryer sheets (Downy, Bounce, etc.) and Attach it to places under the hood where it won't catch fire. The smell is strong enough that it will keep animals away!
  • Elantra Touring GL, Automatic
Offline sheepman
      Peebles
Was in a shed once bedding down cattle with straw looked round to see a cow chewing all the wires off the starter motor on the tractor ,had to use another tractor and a chain to tow it out the shed as it could not be started
  • 2 litre diesil crdi premium
 :eek: :(
