Need replacement Sliding Blocks for window regulator
CRC · 2 · 1120
Offline CRC
      NSW
Front right hand side window has a broken the sliding block on the Electric Window Regulator.
My internet search only identifies replacement sliding blocks as available from the UK / Germany or a US site that sources from Turkey.
Does anyone have contact details of a supplier within Australia or a recommended O/S supplier that delivers fairly quickly.
Car
i30 2009 SLX CDRi
Apologies in advance - still learning the site and how to update my profile.
  • i30 FD 2009
Car
i30 2009 SLX CDRi
You may  find some in Ebay or Gumtree but I've got mine from a seller in Turkey and they send them quick although this tiime of the year may slow things a little.
:link: 2X Window Regulator Repair Clips Brackets Front Right Door for Hyundai I30 2007 793198088263 | eBay
Bross
BWR5018
getting a little pricey with shipping + GST  but still a cheaper  alternative. I usually get 4 to spread the shipping. Last order I got left and right front. They all fail eventually.
I bet it was the one closet to the lock that cracked? And the other is intact? I have only ever replace the one, done thre of my cars now, going ok.
Also there may be a little black bumpstop in the bottom of the clip, save it and fit it to the new one, stops a hard landing at the end of travel but often they are long gone and or disintegrated.
Also seen some repairers quoting total recondition , remove and refit with heavy duty  reinforced updated sliders, around $385.
or $220 exhange But you can get a new genuine from Adelaide for under $200. More work as you'd have to drill the rivets out and swap over the speaker
My BullShit meter is peaking out at this point.
I always have a couple on hand just in case
Bross
BWR5018
Fairly confident they're all going to be similar.
I'll drop a PM too you.
