I had the same issue. Run the update again and it worked fine
... do you know if this update will also work with i30 GD3??
Any chance i could get a copy of the file too?
Could I also ask please for the link to the firmware?
3 cheers for @Shambles
^ watch yer inbox for an early Xmas present
Ok Tim, it's on its way. Usual caveats apply - if it screws your system don't blame us
Quote from: Shambles on December 12, 2017, 11:50:58Ok Tim, it's on its way. Usual caveats apply - if it screws your system don't blame us Wow, so quick!Thanks Shambles, greatly appreciated.Cheers!
Quote from: timoc on December 12, 2017, 12:20:40Quote from: Shambles on December 12, 2017, 11:50:58Ok Tim, it's on its way. Usual caveats apply - if it screws your system don't blame us Wow, so quick!Thanks Shambles, greatly appreciated.Cheers!Buggar! No luck here.Copied the file tll3000h.hdf as is on to a freshly formatted USB stick and inserted into the USB socket with Audio system on. Just got the message "no media files found" (or something close to that)Think I will need to ring the dealer tomorrow. The mY18 is fully advertised as supporting Android Auto, so no idea why it is no istalled good to go. Thanks again for the assistance!
Quote from: timoc on December 12, 2017, 12:42:00Quote from: timoc on December 12, 2017, 12:20:40Quote from: Shambles on December 12, 2017, 11:50:58Ok Tim, it's on its way. Usual caveats apply - if it screws your system don't blame us Wow, so quick!Thanks Shambles, greatly appreciated.Cheers!Buggar! No luck here.Copied the file tll3000h.hdf as is on to a freshly formatted USB stick and inserted into the USB socket with Audio system on. Just got the message "no media files found" (or something close to that)Think I will need to ring the dealer tomorrow. The mY18 is fully advertised as supporting Android Auto, so no idea why it is no istalled good to go. Thanks again for the assistance!Luckily you didn't brick your head unit the file is for different model stereo
Quote from: CraigB on December 12, 2017, 12:51:55Quote from: timoc on December 12, 2017, 12:42:00Quote from: timoc on December 12, 2017, 12:20:40Quote from: Shambles on December 12, 2017, 11:50:58Ok Tim, it's on its way. Usual caveats apply - if it screws your system don't blame us Wow, so quick!Thanks Shambles, greatly appreciated.Cheers!Buggar! No luck here.Copied the file tll3000h.hdf as is on to a freshly formatted USB stick and inserted into the USB socket with Audio system on. Just got the message "no media files found" (or something close to that)Think I will need to ring the dealer tomorrow. The mY18 is fully advertised as supporting Android Auto, so no idea why it is no istalled good to go. Thanks again for the assistance!Luckily you didn't brick your head unit the file is for different model stereo Yeah, disaster avoided thankfully.Closer inspection on the details of the Tucson, and it seems the latest Highlander model still does not support Android auto. I was deadset keen on having it, and when I decided to go with the more expensive HL, just assumed that Android Auto would be included due to the fact it was available on the lower models. Lesson learned Does anyone know if it is actually possible to have it installed at a service dept, or does it just not support it at all?Cheers
