I think Tim refers to the online iCare now, by the way Diesel = Timing Chain, not a scheduled replacement item..
looking at the price iCare quotes, you poor fella $1130
Get a Service Quote - Hyundai AustraliaThis is what it says they do.
Carry out complete global diagnostic system (GDS) check
Check operation of instrument warning lights, gauges & illumination
Check vehicle for outstanding recalls or service campaigns
Inspect SRS air bag & pre-tensioners
Inspect air conditioner refrigerant/compressor
Inspect battery terminals & condition
Inspect brake fluid
Inspect brake fluid condition
Inspect cooling system level, hoses
Inspect crankcase vacuum & ventilation hoses
Inspect disc brakes & pads
Inspect drive belts
Inspect drive shafts & boots
Inspect evaporator pollen filter
Inspect exhaust system
Inspect fuel lines, hoses & connections
Inspect fuel vapour hoses & fuel cap
Inspect operation of lights/wipers, controls & accessories
Inspect park brake
Inspect seat belt webbing & operation
Inspect steering rack & all linkage components, boots
Inspect suspension for damage & torque all mounting points
Inspect tyres including pressure & tread wear
Inspect vacuum pump & hoses
Lube door, boot, bonnet hinges & latches
Replace air cleaner element
Replace auto transaxle oil
Replace engine coolant
Replace engine oil & filter
Replace fuel filter
Rotate wheels front to rear
@cruiserfied worth waiting for Tim's input though.
