Login
Register
Menu
Home
Forum
Search
Gallery
Help
Contact Us
June 06, 2024, 11:59:23
GOT PROBLEMS OR ISSUES?
GENERAL
broken fuse
broken fuse
petran58
6 ·
1831
« previous
next »
Print
Pages:
1
Go Down
petran58
2nd Gear
22
Greece
greece
i30 2008 1.4 petrol
broken fuse
July 09, 2014, 19:31:50
Hi, I have a problem with the electric fuse. more specifically the right lighter (name FR P/OUTLET fuse) . burned and changed the fuse and then broke again. I have tried 3-4 times and when i put gps it brokes. (with the other 12v lighter its ok). Meanwhile, for some reason and the fuse of headlights brokes (head lamp fuse). what could be wrong? sorry for my very bad english
i30
FatBoy
V.I.P
6,752
Australia
Cygnet, Tasmania
Re: broken fuse
Reply #1: July 09, 2014, 21:56:23
Hi petran58,
I would take the car to an Auto Electrician, and explain to them what is happening. That sort of electrical stuff is way beyond my level of expertise. If it does blow the fuse all of the time, it should be easy to track down, it is the faults that aren't always there that are hard to find. Others on here may be able to provide better guidance.
By the way, your English is very good, a lot better than some of the English on this site!!
FatBoy
Phil №❶
Top Gear
Loco, most of the time!
21,976
Australia
Re: broken fuse
Reply #2: July 09, 2014, 23:59:37
The fuse is designed to protect the wiring of the car from burning. The fuse breaks when there is far too much current being drawn through the wires so it breaks before the wires get hot. Either the GPS plug is faulty or the connector for the socket outlet may have a short circuit which will burn out the fuse until it is fixed. Take that car to an auto electrician as previously advised or your dealer if still in warranty. This could be a sign on a serious fault, so don't delay.
2008 SX CRDi Auto White (Lila)[hr]2010 SLX CRDi Auto Red (Ruby)
Doggie 1
V.I.P
Doggie Connoisseur
31,103
Australia
2019 PD2 Go Petrol, Manual. 30,000 kms.
Re: broken fuse
Reply #3: July 10, 2014, 07:09:56
I can't help you with your car, but your English is good.
Tertius the i30
The Gonz
Admin
Afghanistan Vet
16,761
Australia
Callsign GUNZ
Re: broken fuse
Reply #4: July 10, 2014, 10:03:54
Your English is much better than my Hellenic.
As Phil said, be glad that the fuse is blowing. If not, it would be something melting and causing a fire.
Something is not right and needs to be investigated properly. You are too far from Adelaide for me to help any more.
Frugal Firty: FDSLXCRDi5spHyperSilverBodyKit+Mods & MrsG'sPDSRPrem
Just Rick
V.I.P
Big Dogs Rule
7,617
Australia
Beverley Western Australia
miracles can happen
Re: broken fuse
Reply #5: July 10, 2014, 12:26:46
You have a dead short there some where,as the others have said,back to the dealer if under warranty or off to a auto elec, could get serious if not sorted.
2011 SLX CRDI 6 Spd, 2010 Holden Cruze CD Diesel and 2001 Hyundai Accent Coupe
Print
Pages:
1
Go Up
GENERAL
broken fuse
Search
Username
Password
Always stay logged in
Forgot your password?
