Rear seat covers - 2017 i30 SR PD
dancet · 8 · 5969
Offline dancet
      Townsville, Queensland
Wanted to post some pictures and a quick breakdown of the process. Brand new i30 SR owner, had the car for almost two weeks.
The fronts seats don't have any cover on them, but for the rear I want some covers due to my son regularly being a grub and our dog sometimes being in the back.
I did plenty of googling and didn't find much, other than this site: :link: Car Seat Covers - Premium Quality, Lowest Prices?. I ordered the rear covers in neoprene and they arrived around a week later.
Then the fun of fitting them started. If you want to do the same, here's how:
1. Remove the rear bench seat.
All my previous cars had front folding bench seats, so I had a bit of trouble trying to work the i30's bench out. Eventually I discovered I needed to remove two bolts.
These bolts are easily accessible from the boot if you remove the false floor. I think they were 10mm or 12mm. Easy to remove with a shifter.
Here is a closer look at one side (they are the same on both sides)
Once you have the bolts out, you have to pop the two clips out on the other side of the bench. Hard to photograph, but if you put your hand as shown in the photo and pull up, they just pop out.
2. Fit the cover to the bench seat
With the bench out, it's easy to fit the cover to the bench. I suggest taking it inside and placing it on your bed or a table for ease of access. The cover fits on easily and only one way, you can't mess it up.
3. Fit the head rest covers
You'll need to take the head rests off before you can fit the seat back covers anyway, so might as well fit them now. Simply slide them out and the covers fit straight on. The only trick is identifying which is for the centre, as it's physically smaller than the window seat head rests.
Do not put the head rests back in place yet.
4. Fit the centre arm rest cover
There is a small piece that covers the rear centre armrest. It's a little fiddly to slide it under the hinge, but just work the arm rest up and down a bit and you can slide it under.
5. Fit the rear seat back covers
The last piece of the puzzle. Due to the 60/40 split fold, you have to fit one at a time. The one for the 60% side has a velcro split that allows you to accomodate the centre seatbelt. Simply undo it, slide it under the belt and fold it around the whole seat back. It can take a bit of wrestling to get it lined up well, but once you have it in place it should be fine.
You can also zip up the flap that goes over the centre arm rest. You will know it's in position when the holes for the latch for folding the seats lines up well, same with the holes for the head rests.
Move on to the 40% side, which is a lot easier.
Once it's looking good, slide the ties under the back and move around to the boot to tie them together and cinch the whole thing down. I found this easiest with the seat backs folded down.
6. Put it all back together
Replace the head rests, put the seats back and place the bench back in place. I found it easier to slide the rear metal tabs on the bench in first, then snap the front ones into their slots by sitting on the seat. With it roughly in place, it's easy to put the bolts back in and tighten them up.
Once done, make some small adjustments and you're done!
So far, I'd definitely recommend these seat covers. They are well made and fit really well. I was surprised with the precision of some of the cut outs.
Knowing what I know now, I think you could have this done in 30 minutes. Any questions, let me know. Thanks!
  • 2017 PD 4 Door Hatch, Petrol 1.6lt, DCT, Polar White
Offline CraigB
      Perth, WA
Looks good :goodjob2: they're well worth the money when dealing with children and pets.
I wish I'd had the neoprene covers in the back of my VK brockie after my Malamute decided to eat a dead blowfish down the beach and threw up disgusting green vile all over my rear seats :sicky:
 :welcumwagon:
Wow! What an excellent 1st post! Thanks very much.
Just playing with their site, looks like you only paid $199 including free postage! That is cheap for neoprene!!
$400 for a full set!
I paid $500 just for custom made sheepskin (front only) for my SR and they reckon I was under quoted (should have been about $700) :crazy1:
Offline dancet
That's right, $199 delivered for the rear. I was really impressed with the fit and finish on all elements. It appears the company makes them on demand.
$199 well spent!
Offline romi05
      Qld
Looks like the same covers we got...A real score for $348 shipped (they had a deal on eBay) How I wish we had seen your post before we started on the back seats! It was too easy after we finally figured out how to get the lower bench seat out. We also spoke with the seat cover technical assistance fella & sent him pics as well for their next customer with questions👍
  • 2018 PD 5 door Hatch Premium, Diesel 1.6 DCT Marina Blue
Offline romi05
      Qld
That was for front & back covers...
Offline Eliseszy
      Brisbane Queensland
Thank you so much for this especially the pics. Will refit my rear seat covers tomorrow so they'll stop annoying me and stay in place.
  • 2021 PD v.4 Active Hatch
Offline Eliseszy
      Brisbane Queensland
Have now properly fitted the rear bench seat cover and tidied up the back rest covers. Very happy with the fit and appearance with the covers I purchased.  Was pleased that the bench seat is quite light so I didn't need any help with moving it.  Took your advice and put it on a bed to fit the cover on.
Another huge thank you for such an excellent post.
