Removing 5th door upholstery
Ogi · 5 · 1995
Offline Ogi
    • cs Serbia
      Belgrade
  • Belgrade, Serbia
Did anyone do this ? I need to remove it in order to tighten the screw or something on rear wiper mechanism which is unloosen making the wiper unloosen too.
There are no secrets to this apparently. Checking the manual it says, "Remove interior trim" :Dunno:
Haven't tried it on a Hyundai, but from other brands my experience is that it's just clipped on.
Check if there's any screws, if not, then just pull it off.
Offline Ogi
    • cs Serbia
      Belgrade
  • Belgrade, Serbia
Well, from my experience whenever i thought that something is going to be easy, i got stuck with something. :-) Thats why i ask. There are 4 screws but i dont know if its also glued other than screwed becouse ti seems so maybe. Also, i dont know what i will find there if i take it off and is it easy to get it back on as well as will the locking mechanism be a pain for removing it. :-)
As I stated b4, there are no special instructions in the workshop manual, 1 sentence "Remove the interior trim." that's all , so it can't be that hard can it.
The wiper mechanism is attached by 2 bolts which are NOT part of the latch mechanism. You stated that  a bolt is loose, so removal is not required, just tightening, however, I would probably put a thread sealer on both bolts just to make sure that you don't have to go back there ever again.
Torque settings for the bolts
Tightening torque Nut :
10~14 Nm (1.0~1.4 kgf.m, 7~10 lbf.ft)
