Does this model have the ?? (Can't recall name) rings on the drive shaft?I ask cause on my accent the ring had split so was giving an odd reading causing the abs to applyReluctor rings - yes it does
Does this model have the ?? (Can't recall name) rings on the drive shaft?I ask cause on my accent the ring had split so was giving an odd reading causing the abs to apply Administrator Comment Reluctor rings - yes it does
Sorry - and no lights on the dash come on either. The Reluctor rings sounds a clue - I'll get the dealer to check. Thanks for your input - will keep you posted.Gary
