Hatch; Locks with halo, unlocks when exiting the car or removing the key from the ignition (tested with 2nd person).
after a few head scratching minutes I tried the boot bingo! not locked climbed through to oper rear doors then drivers one.Not so sure of Halo now.
That could have been embarrassing if you were parked in a busy area..
Well i've done it ! Locked myself out of the car with the engine running !!!!I have halo active and up till now have found it very good, but after pulling up at the post box, got out, shut door, posted letter, unable to get back into the car, the catch inside by the handel was in the open position but you could not open the car from the outside. after a few head scratching minutes I tried the boot bingo! not locked climbed through to oper rear doors then drivers one.Not so sure of Halo now.
...When you open your door HALO should unlock all doors and deactivate...
I did it once in a busy street...Don't know why I did it but can still remember the embarrassment
