One question...
KKOM · 3 · 2305
Offline KKOM
    • gr Greece
      Heraklion
For those who already have on their i30 install HID kit...
I just received yesterday my 55W 4300K HID KIT and today I try and remove the headlight and check where is the best place to install the ballasts then I remove the low beam cap and the H7 bulb to check if the xenon is short enough to fit and so far so good...
And here is my question....
By checking the bulb connector I saw that the colors of the 2 cables are green and black with a thin white line.The xenon 2 male connectors are red and black( + and -).
To be sure I remove the high beam cap and I check the hi beam connector and it has black cable...Is the low beam (black wit white line) cable the "-" ????...
Offline Hemmi
    • is Iceland
      Reykjavik, Iceland
Unless Hyundai wants to invent the wheel again, black is ground, There's just no way the green one is ground, unless it's light green with a twist of yellow, but I think you only find that kind of wiring in your house or electronics.
Offline freakzoide
I would say green is the nagtive. I have hid kit on my ceed, but I don't remember the color code on th cables.
