Why the warranty was good
Lorian · 9 · 2454
Warranty expired last week.
In the 5 years:
Year 1
New Radio (Traffic Announcement issue)
Glue rear shock covers
Year 2
Nothing
Year 3
Ignition key spring fix (intermittent doors not locking)
Year 4
Headlamp Wiring fix (TSB for bulbs blowing)
Drivers door latch cable (TSB for cable breaking)
Year 5
New Brake Light Switch (TSB for faulty switches)
New Flywheel (vibration at idle)
New 3 part clutch kit (noise at 1800 rpm+)
New Washer Sensor (light always on)
New External Temperature Sensor (8c all the time when not 8c)
New immobiliser reception Coil (intermittent fail to start, random fuel pump P codes)
New Air conditioning Condenser & Re-Gas. (Condenser leaking, not holed by stone)
Those marked (TSB) were pro-active fixes for faults I did not report.
I thought it only fair to get my money's worth In year 5  :lol: . To Hyundai and Dealer's credit I NEVER had to argue to get anything fixed, even with the (noisy, not worn) clutch in the last 4 weeks of the warranty.
Sat on the fence about buying a new one in 2015.
« Last Edit: December 17, 2014, 19:28:51 by Lorian »
Offline asathorny
  • Wonky Donkey
  • Curmudgeon
Although they would be classed as minor issues, in the grand scheme of things on a car, you can see the worth of a 5 year warranty as the majority are in years 4 and 5 which would be outside warranty period with the majority of makes.
 :goodjob2:
Thanks Lorian  :Agoodpost:
Offline diablo
      Blackpool
I'm in the same boat and sat on the same fence.  :mrgreen:
Do I trade in when March arrives next year, or assume that as nothing serious has happened yet then it will plod on without problems?  I only do a low mileage so maybe that helps the cause for keeping it, plus I'm mean and don't like spending money.  :lol:
Offline Johnno
      Bolton, Lancashire
just shows having the extra 2 years compared to other manufactures has saved you a lot of dosh, must be a couple of grands worth  with parts and labour. :goodjob2:
Thanks.  :goodjob2:
How many miles during this period.. :question:
Offline Talking Hoarse
      Winchcombe, Glos
I think Lorian has done well!  My 2010 facelift CRDi auto has had (not including the tsb's which I dont see as faults as HUK have been "proactive"):
Radio
Instrument Cluster
Automatic gearbox
Re-bonded front bump stops
Windscreen wiper arm
Steering column including eps
Gear knob
Re-bonded 4 bump stops
Osf door latch
Osf window motor
Gear control cable
Replaced egr valve
And the car is not right /in dealer as I write.
This is a car that has never been abused, overheated or been misfueled etc in its 52,000 miles approx.  However I reckon my woeful experience is not typical - indeed the AA man that attended the breakdown (that led to egr valve) couldnt believe it was a breakdown and initially strongly suspected misfuelling or dpf issue (he was wrong).
To be honest, I have had lots of cars that I have owned into old age with daily active use, but never felt such an acute need for a warranty.
Fingers crossed for a better 2015
Ed
Offline Mike SX
      Essex
Some posts should be renamed Why the Warranty was needed
