Broken Spark Plug - not changed during service - VOIDED WARRANTY?
JUDY · 177 · 42584
Quote from: CraigB
But there is a time frame if you look at the schedule she posted, 45000km's or 36 months/3 years...which ever occurs first
I can't see where it says 36 months.
Offline Wingerdave
  • Brummie born and bred
    • nl Netherlands
      Raamsdonksveer
Somebody is telling fibs..... But, Judy's maintenance book does clearly state 40,000 km, without a time frame.
It is not up to the consumer to interprate what Hyundai mean, or to contact them asking if maybe they've changed the conditions recently.
If it says 40,000km and the car has done less, then Hyundai should cover it, not refer to conditions that aren't mentioned in the only written information readily available for the consumer.
Just my take on it.
I think if you look closely somewhere in the book you'll propably find something like "due to changes without notice"
And how would the average Joe (or in this case, Judy) recieve notice of these "changes" without notice? Quite a Catch 22 isn't it.....
Offline CraigB
      Perth, WA
Quote from: CraigB
Sorry! I got the lines mixed up on the schedule and was reading the air filter replacement interval :head_butt:
After checking my own maintenance schedule my book say's 60,000kms or 48 months.
Just my take on it.
She wont, unless she takes her car to be serviced at a Hy dealer or an indy that makes sure to use updated service schedule and not just look in the service book. It's not just Hy doing that....
Offline JUDY
      Melbourne, Vic
Hi All.
When my car was fixed the mechanic (reputable) did a compression test and no problem with no3 or any others.  Just a broken spark plug.  Didn't take my preferred mechanic a long time to figure that out....well not as long as it did for Lilydale Hyundai to produce their report.  it's a mystery to me why my car hasn't completely curled up it's toes given that it hasn't had anything other than a service with new plugs and a compression test done???
  • 2010 i30
Hi All.
Great news Judy! So the fix only cost you a service with new plugs + the towing and exploration costs at Lilydale?  :undecided:
Offline JUDY
      Melbourne, Vic
Yes Dazzler.  Car all fixed for $99.  My main gripe with Lilydale Hyundai is that I felt they saw it as an opportunity to exploit and profit from my misfortune with the spark plugs not being changed and I still feel that the broken spark plug is bizarre.  I was just talking with my husband about it and he pointed out that the broken plug was in 3 and not in 4 as I think Hyundai stated in their response.  This further points to either ineptitude or complete fabrication of their response.  Poor, Poor, Poor customer service.  Best business models have at their heart that you shouldn't treat your customers with contempt and lack of respect.  Also don't think that the general public will believe any load of crap you try to tell them.  Lilydale and also Nunawading Hyundai (jointly owned) should view their reviews online because I believe bad reviews speak greater volumes than the occasional good one.
If wrong on any of the above I stand corrected?
  • 2010 i30
Offline JUDY
      Melbourne, Vic
Just wanted to add.  I have no idea what RACV Report they are talking about because my car was towed in by a private mechanic?????
  • 2010 i30
Offline Johnno
      Bolton, Lancashire
great news Judy, you should march back into them and tell them your findings and see what they have to say
Thanks for the feedback, Judy. Good to hear you could get the car repaired at so low cost, but I do understand your frustration about Lilydale. Something doesn't add up here.
Offline Wingerdave
    • nl Netherlands
      Raamsdonksveer
Fantastic result, Judy.  :goodjob:
Offline tohis
      Liperi
Hi Judy, good to hear your car is okay now. My workmate wasn't so lucky with his Ford Focus few years ago. He just changed new spark plugs to it, and the next day he noticed some nasty pinging sound coming from the engine. It turned out that the side electrode from one of the old spark plugs was missing, probably broken when changing them and went unnoticed until it was too late.
Inspecting the cylinders by an endoscope revealed lots of damage inside one of cylinders. With modern engines that means the whole block is ruined, because you can't bore the cylinders and rebuild with oversize pistons like in the good old days. He then found a replacement engine for it from a scrap yard.
Offline crayman
      Gympie
Judy the report mentioned a leak down test done on No4 and concluded air was leaking via No3.
Nothing more, so an inconclusive test.
The whole idea of leak down testing is to isolate a problem whether it be head gasket, leaking inlet or exhaust valves or blow-by.
To me their test was a waste of time as it proved nothing.
If your car had done the head basket, you would certainly know by now.
Leaky valves, can't comment as the test didn't give results, same for rings etc.
As for the whole sorry sage, I'd try to move on and forget it.
Car is out of warranty now and you seem to have found a reliable workshop for future servicing, so happy motoring.
(on NGK plugs)
  • i-30
Thanks for the clarification Judy.  :victory:
Offline How I Roll
      Inala, Qld
I've seen this on 2 veloster turbos, poor fuel quality causing detonation and premature fatigue of the earth on theend of the plug. 1 was luckey the other one punched a hole in the exhaust valve, surprisinglytheturbo was okay.
Thanks, interesting. ..
Offline ibrokeit
  • Author of War & Peace
Sounds like your in the industry.  Independent service center/garage?
Probationary Hyundai master tech.
Do you know or aware of Tim?
Quote from: How I Roll
No, sorry. If a name or acronym?
It's an acronym.
The International Mastertech :whistler:
AKA cruiserfied on here
Here is write up on him:
:link: My writeup on GoAuto news
Offline How I Roll
      Inala, Qld
Offline ibrokeit
Nice.
Offline How I Roll
      Inala, Qld
Very impressive, i am really only at the start of my career, trained in Queensland.
Offline cruiserfied
  • Crooked-H Hero
Ahh, i have seen alot of his posts. I pop in here occasionally.
And now you've seen one more  :crazy1: :crazy2: :lol:
