discs
alli · 3 · 2083
Offline alli
      scotland
i own a 2014 i30 1.6crdi  automatic , can anybody tell me if the front brake discs are the same as a manual as their seems to be some confusion.their is plenty discs but they dont seem to be compatable  with an automatic.thanks, alli.
  • i30
What size rims did it come with from the factory? Or measure the outer diameter of the rotor
517122L500 16in wheels
:link: Brake Disc OE Number 517122L500 buy online
Parts Details:
Fitting Position:
Front Axle
Outer diameter [mm]:
300
Brake Disc Type:
Internally Vented
Centering Diameter [mm]:
69,1
Rim Hole Number:
5
Bolt Hole Circle Ø [mm]:
114,3
Thickness [mm]:
47,3
Brake Disc Thickness [mm]:
28
Minimum thickness [mm]:
26,4
51712A6000 15in
:link: Spare Part 51712a6000
iameter [mm]:
280
Brake Disc Type:
Internally Vented
69,0
Hole Arrangement / Number:
05/07
114,3
23,0
Surface:
Coated
21,0
Height [mm]:
44,4
That's all I can see at the moment
Offline BrendanP
Companies like Pagid, Delphi, Brembo, Ferodo, have online catalogues where you can search using the car Reg no, and they'll describe the correct parts. I suspect the disc diameter is the same for 15" or 16" wheels, the bigger diameter discs will be fitted on higher power vehicles. If in doubt, take a wheel off and measure it.
