i30 1.6 crdi clutch problem
WxmJax · 3 · 6227
Offline WxmJax
      North of Watford
Hi, there is a problem getting the car in to reverse without crunching the gears. It has occasionally happened in first but mostly reverse. I would say about 8 out of 10 times  it occurs.
 No other problems with the gears. I changed the gearbox oil but no success. Car is 2012 GD blue drive manual with 86,000 miles on it.
  • 2013 GD 1.6 110ps man diesel estate.
I know in the FD it appears as things get on the clutch fails to disengage completely or drags a bit. assuming the design in GD is similar sounds like it could also be suspect. Reverse being a non synchro gear you will get a grind going as opposed to the forward gears which you've likely felt notchy or stubborn to get in to.
Don't have a solution  but the damper on the hydraulic circuit has been theorised to go soft internally and reduce pressure and travel at the end point. Some have removed it and blanked it off with a sump plug.
It is frustrating that there is no way to adjust the system at the clutch pedal, not that I can see.
i am talking from the FD series point of view.
Offline WxmJax
      North of Watford
I've found this on YouTube, not sure how easy it is to do yourself though, that's even if it's the same in the GD model, wife has car at the moment.
:link: Hyundai i30, Low Clutch, Gears Grinding - FIXED - YouTube
