Engine management light problem
gavdar · 2 · 4596
Offline gavdar
    • ie Ireland, Republic of
      Galway
Recently engine management light came on on my 2017 1.6crdi.
When it was read the code given was C14OOO.The light went out
after being reset.Just wondering if anybody has found this code
before
  • 2017 i30 crdi
Hello!
Please check the code you typed above as it doesn't appear on any Hyundai DTC website I know of :)
Here's an example list:  :link: OBDII diagnostics. Trouble codes description for HYUNDAI
If, however, you meant to type C14000 (zeros, not letter "O"s) it might indicate an engineering code not a fault code, and on a Ford would indicate "Traction control value right front circuit failure" (courtsey of El Googly)
